Yes or No on a Form to Suppress a feature
AMN3161
Message 1 of 20
AMN3161
Hello everyone,
I am rather new to ilogic, i just do simple rules most of the time.
What I am trying to is that I build a form to automatically created a lifting diagram for lifting our sytems. I want a option to better show the position of something through a Custom "Yes or No" Iproperty to suppress a feature. All of the search results have been for building a yes or no pop up through the Ilogic.
I want to use the Custom Yes or No Iproperty that is controlled through a Form, then that form selection will tell a certain feature to be suppressed.
How would i go about doing that? just even a small example will be enough for me to build off of
thank you
Replies (19)
Message 2 of 20
philip1009
Here's a quick sample:
SyntaxEditor Code Snippet
If iProperties.Value("Custom", "PropertyName") = "Yes" Then
	Feature.IsActive("featurename") = True
	'Or
	Component.IsActive("Part1:1") = True
	'Etc.
ElseIf iProperties.Value("Custom", "PropertyName") = "No" Then
	'Etc.
Also, on your Ribbon, go to Manage > iLogic > Event Triggers, and then you can set the rule to run automatically when the right event occurs, such as iProperty Change.
Message 3 of 20
AMN3161
I will give this a shot, out of curiosity, what does "Etc." do?
Message 4 of 20
philip1009
Sorry I should have explained, whenever you put an ' in code, anything typed in after that will be ignored by the code and will be grayed out in the iLogic code editing window.  It's basically used for personal notes or comments, same thing with the 'Or, you can just erase that and put in your code.
EDIT:  If you're interested, here's a YouTube playlist for a tutorial on Visual Basic, which is what iLogic uses, there are slight differences between Visual Basic and iLogic, but it's mostly the same:
https://www.youtube.com/watch?v=1mg3NHwGkas&index=4&list=PLC601DEA22187BBF1
Message 5 of 20
AMN3161
I tried using that rule and i am getting a error saying that it can only be used in a assembly. I may of not described it well but i need the  Yes or No form box to suppress a feature within a part file.
Message 6 of 20
philip1009
If you meant turning a part feature on or off from an assembly level:
Feature.IsActive("Part1:1", "featurename")
Message 7 of 20
AMN3161
I am trying to suppress a feature within a ipart. There is no assembly in this situation. I tried to manipulate the code you originally gave me to try to get it to work at the part level. I think is see how you built the first sample you gave me.
I am getting this error now "Conversion from string "Yes" to type 'Boolean' is not valid."
Basically what I am trying to build is a lifting spreader bar so we can show lifting details on how to lift out 20,000 lb + systems. This lifting ipart will be used on many different size and orientation skids.
If iProperties.Value("Custom", "Lifting_Ears_Option") = "Yes" Then
		Feature.IsActive("Rotate 1") = True
ElseIf iProperties.Value("Custom", "Lifting_Ears_Option") = "No"
Message 8 of 20
bradeneuropeArthur
You can do this without programming.
Do you like to know how?
Or isn't this what you need?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 9 of 20
philip1009
There's the issue, iParts use a different line of code.  Any different iParts have to be managed in an iPart master file.  Then you change the iPart row to use in an assembly, if it's an iAssembly, then manage iPart rows in the iAssembly table.  If it's a regular assembly and you want to change which iPart row to use in an assembly you have to use the snippet:
iPart.FindRow("iComponentName:1", "columnName", "<=", 0.2, "columnName", "<=", 4.1)
You don't need to use the last 3 statements if you don't need them, just leave them blank.  Input the column name such as part number or Length, then use = < > or a combination of those, then input the number, boolean or string to compare.
Message 10 of 20
AMN3161
The part I have is not a ipart factory, it is just a standard ipart with a form driving a couple dimensions. I just need the a custom iproptery that i created that has a "Yes or No" option to drive the suppression on a "Move Body" Feature.
Message 11 of 20
philip1009
Every iPart is either the factory master or is exported from an iPart factory.  I'm guessing you're just copying a factory master as a template.  Here's a sample code for you:
'Yes on Custom Property = True, No on Custom Property = False
If ThisDoc.Document.PropertySets.Item("Inventor User Defined Properties").Item("PropertyName").Value = True Then
	Feature.IsActive("Move Body") = True
Else
	Feature.IsActive("Move Body") = False
Make sure to set this rule in your Event Triggers under iProperty Change.
If this doesn't work you might have to provide a sample of some kind.
Message 12 of 20
AMN3161
That is exactly what i needed, really appreciate it!
Thank you!
Message 13 of 20
bradeneuropeArthur
This all can be done easier without programming.
Why you need illogic or any programming for this if you can do  it with parameters and suppression.
This is out of the box inventor and no additional knowledge is required!!!!
please let me know if you need an example!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 14 of 20
AMN3161
I wast not aware that a iproperty Yes or No selection can be used to suppress a feature. Can you show me a example?
Message 15 of 20
bradeneuropeArthur
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 16 of 20
philip1009
What @bradeneuropeArthur is talking about is if you right click a feature and select Properties, you can choose to have the feature suppressed based on a parameter, but it's not possible to use this for iProperties.
Message 17 of 20
bradeneuropeArthur
That's correct, but you can export the parameter as property too.
This means the suppression is based on the parameter, but the same property will be created...
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 18 of 20
AMN3161
Well that will help me later on something other features that I am building into this part. thank you
Message 19 of 20
philip1009
You can only export numbers from Parameters to iProperties, text and boolean has to be through code.
Message 20 of 20
bradeneuropeArthur
@philip1009
That is correct.
But this is inventor out of the box.
I thought it would help.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
