iLogic AddTitleBlock E_INVALIDARG
mallorn
mallorn
I'm struggling with re-writing  the same program that I solved already...(lost file), but as I remember last time I had all my PromptedStrings given in array.
here is my iLogic code:
SyntaxEditor Code Snippet
If ThisApplication.ActiveDocument.DocumentType = DocumentTypeEnum.kDrawingDocumentObject Then
	Dim oDoc = ThisApplication.ActiveDocument
	Dim oSheet = oDoc.ActiveSheet
	Dim oProdBlock As TitleBlockDefinition = oDoc.TitleBlockDefinitions.Item("PRODUCTION")
	Dim oTitleBlock As TitleBlock
	If oSheet.TitleBlock Is Nothing Then
		oTitleBlock = oSheet.AddTitleBlock(oProdBlock)
I have "PRODUCTION" in My Title Blocks, no title block is activated while Rule is started.
I still receive the e "E_INVALIDARG"
What do I do wrong?
Tomasz Malinowski
Mark.Lancaster
@mallorn
Inventor programming issues and questions should be asked in the Inventor Customization for best results.  I will have the moderator relocate it there to better suit your needs.
https://forums.autodesk.com/t5/inventor-customization/bd-p/120
Mark Lancaster
chandra.shekar.g
Autodesk Support
Autodesk Support
@mallorn,
Try below iLogic code. There might be default title block is added on adding new sheet. So, need to delete first.
        Call	oSheet.TitleBlock.Delete
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
mallorn
Thanks, there is an empty sheet without default block.
I tried with default ISO drawing template with ISO TitleBlock and code works (even when I copy ISO title block to my drawing).
There must be something wrong with my title block... which is working if I'll add it manually.
Tomasz Malinowski
mallorn
@chandra.shekar.g- I have sent you PM with a link to my Drawing file asking to check the Title Blocks.
Tomasz Malinowski
chandra.shekar.g
Autodesk Support
Autodesk Support
@mallorn,
To add "PRODUCTION" titleblock, Promptstrings are required. Which is third parameter of "Sheet.AddTitileBlock"
Sheet.AddTitleBlock( TitleBlockDefinition As Variant, [TitleBlockLocation] As Variant, [PromptStrings] As Variant )
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
