Writing a function in inventor iLogic
Hello, I have a small issue with an if statement I am trying to right correctly. The statement involves a pattern and the length of my part.
I need a message to appear if someone inputs a length that isn't divisible  by inputted centers to come out to a whole number. So for example:
Someone inputs 112 for length and 3 for the centers into the form. The answer to that is 37.33333333. Since this is not a whole number I would like it to show an error.  On the other hand if someone inputs 120 for length and 3 for the center then that works perfectly and no error would appear.
I feel it is probably simple but I am sure someone knows more then me about it. Please if anyone has a snippet of code to share that would be extremely helpful.
bradeneuropeArthur
The following:
Public Sub Main()
Dim x As String
x = Divide(112, 37)
MsgBox (x)
End Sub
Public Function Divide(a As Integer, b As Integer) As String
Dim iresult As Integer
iresult = a / b
Dim Dblresult As Double
Dblresult = a / b
If iresult = Dblresult Then
Divide = a / b
Else
Divide = "error"
End Function
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
