- Mute
- Permalink
- Report
I have created a simplified version of a standard box we fabricate. This box varies in height, width and depth, also divider qty's and spacing varies. I linked all the part parameters to top level assembly parameters, so the user can modify the box. The form works great, assembly updates accordingly parts suppress as required.
This is where I am running into issues, suppressing parts requires a LOD, and every time something changes or gets added, an error comes up, it doesn't seem like it affects anything, but working in a LOD makes things difficult, I forgot to take a screenshot of the BOM issue, but it is something along the lines of creating a parts list causes an error due to the BOM not saved in the assembly. Eventually the assembly gets saved, and then the drawing parts list does get saved also.
upon researching this error, I found this thread and it basically states that LOD's shouldn't be used for assembly/product creation, it should only be used to open up large assemblies to save loading time. Which make sense. It also states that the user should just toggle the visibility of parts and update the BOM accordingly by filtering the view reps.
I don't think manipulating the BOM is correct as there is an option for human error.
In the attached assembly, the user opens the form, inputs the desired dimensions, and inputs, based on that the assembly then suppresses the appropriate components. Again, this is a very simplified version, there are many more components in the actual assembly. I can change the suppression part in the rule to toggle visibility, but then the qty's would be off and have to be manually input or configured.
Also this assembly is stored in a Templates folder, from there I use iLogic Design Copy and add the project number as a prefix and save to project location. Doing this renames the parts, inside the rule, the parts are still referenced to the original "Template" file names and not the new prefixed project names, looking for ideas on how to be able to manage this aswell.
Hopefully this makes sense,
Thanks!
Sean
Product Designer at Teksign Inc.
Inventor 2016 SP1
Dell Precision 3660
i7-12700 @ 2.40GHz-4.90GHz
32GB DDR5 4400MHz RAM
NIVDIA RTX A2000 6GB
