Word file into PDF
Word file into PDF
martinhoos
Word file into PDF
martinhoos
Hello Forum,
i have a code that created a word file, save it and quits word.
My question: Is it possible to create additionally a PDF file?
'Save the Word file with a new name and close the document
wordDoc.SaveAs (ThisDoc.PathAndFileName(False) & ".docx")
wordDoc.Close()
wordDoc=Nothing
If i change ".docx" into ".pdf" there will created a defective PDF File. What do i wrong?
Very best regards
Martin
philip1009
Is this Inventor related?  If you're looking to save a drawing as a PDF there's a much easier way than going through Microsoft Word, there's plenty of PDF export code examples on this forum for you to use.
bradeneuropeArthur
  Public Sub pdf()
ThisDocument.SaveAs2 "C:\Temp\MyDoc.pdf", 17
  End Sub
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
martinhoos
... thanks ...
martinhoos
Hello Brandeneurope,
thank you for your reply - that runs! So i can create out of Inventor a word file with data from Inventor and also save this as pdf.
thanks a lot
Regards Martin
