2018 BOLTED CONNECTION COMPONENT GENERATOR - TEMPLATE LIBRARY LOCATION???
sguan1212
sguan1212
Hi, I want to start using more bolted connection command to speed up my productivity.
I've saved a few bolting assemblies in the Template Library.
I want to know the location of the saved up files so I can share it on other colleague's computers.  Can someone help..
We are currently on 2018 version. See attachment for a snapshot.
Sean
AlexFielder
The answer to this is... complicated.
I've just run some tests and when you create a new bolted connection it edits the index.xml file here:
C:\Users\%username%\AppData\Roaming\Autodesk\Inventor 2019\DesignAccelerator\Templates\CABoltCon\index.xml
The templates themselves are also placed in this folder but are given a GUID-type filename:
The index.xml file then gets a reference to each new file's GUID with a "Node" prefix:
<?xml version="1.0" encoding="UTF-16"?>
<FDesign RecentlyUsed="C7F4D760-C82F-4ECC-8DCD-21859BD1B86D"><NodeC7F4D760-C82F-4ECC-8DCD-21859BD1B86D/><NodeCF06171C-BC49-417C-BD7D-6F7E7632E607/><Node7CEF0F17-3BFB-4FB3-B563-677F5F4A57CB/></FDesign>
The filename and part-data from one of the  Bolted Connection template filesThe filename and part-data from one of the Bolted Connection template files
Sharing the templates should simply be a case of copying the template (GUID-named) files and the index.xml file to the relevant user path on other systems you want to share the template with.
sguan1212
Thanks you very much for that!
I've came across this same file address earlier on the net, but wasn't able to navigate my way to them. This time i persisted.
The key here is to turn on the hidden files/folders in Windows, this will make AppData folder appear
