Win11?
Win11?
Log0ut
Message 1 of 17
Win11?
Log0ut
Hi
I'm using follow code to generate PDF from drawings:
 '------start of iLogic-------
oPath = ThisDoc.Path
doc = IO.Path.GetFileName(ThisDrawing.ModelDocument.FullFileName)
oFileName = ThisDoc.FileName(False) 'without extension
oRevNum = iProperties.Value(doc, "Custom", "rev")
oProduct = iProperties.Value(doc, "Custom", "toode")
oCurDate = iProperties.Value("Status", "Checked Date")
oPDFAddIn = ThisApplication.ApplicationAddIns.ItemById _
("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
oDocument = ThisApplication.ActiveDocument
oContext = ThisApplication.TransientObjects.CreateTranslationContext
oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
oOptions = ThisApplication.TransientObjects.CreateNameValueMap
oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
'get PDF target folder path
oFolder = Left(oPath, InStrRev(oPath, "\"))
'Check for the PDF folder and create it if it does not exist
If Not System.IO.Directory.Exists(oFolder) Then
    System.IO.Directory.CreateDirectory(oFolder)
 'Set the PDF target file name
oDataMedium.FileName = oFolder & "\" & oProduct & " - " & oRevNum & " - " & oCurDate &".pdf"
'Publish document
oPDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
'------end of iLogic-------
In work, win10, everything works. In home, win11, i get
this error:
Unspecified error (Exception from HRESULT: 0x80004005 (E_FAIL))
Has anybody have any idea, what causes this?
Replies (16)
Message 2 of 17
bradeneuropeArthur
Have you show fileextensions on in win11?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 17
Log0ut
Are my file extensions showing in file explorer? yes
Message 4 of 17
bradeneuropeArthur
What message do you receive the last, if you use this coding?
MsgBox("1")
MsgBox("2")
MsgBox("3")
MsgBox("4")
MsgBox("5")
MsgBox("6")
MsgBox("7")
MsgBox("8")
MsgBox("9")
MsgBox("10")
MsgBox("11")
MsgBox("12")
	MsgBox("13")
oDataMedium.FileName = oFolder & "\" & oProduct & " - " & oRevNum & " - " & oCurDate & ".pdf"
MsgBox("14")
'Publish document
MsgBox("15")
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 5 of 17
Log0ut
14, error in line 42
Message 6 of 17
bradeneuropeArthur
test if the add-in is loaded.
Do you receive a true message?
MsgBox("1")
MsgBox("2")
'oRevNum = iProperties.Value(doc, "Custom", "rev")
MsgBox("3")
'oProduct = iProperties.Value(doc, "Custom", "toode")
MsgBox("4")
MsgBox("5")
Dim oPDFAddIn As Inventor.ApplicationAddIn = ThisApplication.ApplicationAddIns.ItemById _
MsgBox("6")
MsgBox("7")
MsgBox("8")
MsgBox("9")
MsgBox("10")
MsgBox("11")
MsgBox("12")
	MsgBox("13")
MsgBox("14")
'Publish document
MsgBox (oPDFAddIn.Activated)
MsgBox("15")
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 7 of 17
Log0ut
Yes, true
Message 8 of 17
bradeneuropeArthur
Test the date-string:
Does it contain non allowed characters like "/"?
MsgBox("1")
MsgBox("2")
MsgBox("3")
MsgBox("4")
MsgBox (oCurDate.ToString)
MsgBox("5")
Dim oPDFAddIn As Inventor.TranslatorAddIn = ThisApplication.ApplicationAddIns.ItemById _
MsgBox("6")
MsgBox("7")
MsgBox("8")
MsgBox("9")
MsgBox("10")
MsgBox("11")
MsgBox("12")
	MsgBox("13")
MsgBox(oFolder & "\" & oProduct & " - " & oRevNum & " - " & oCurDate & ".pdf")
MsgBox("14")
'Publish document
MsgBox("15")
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 9 of 17
Log0ut
That was it- changing date format, solved the problem. Thank you!
Message 10 of 17
Log0ut
I also have another similar problem- if i export drawings to dwg, attached images shows like that:
At work converting works as it must be, using same drawing
Message 11 of 17
bradeneuropeArthur
Can you share that code too?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 12 of 17
Log0ut
I'm using File-Export-Export to DWG option
Message 13 of 17
bradeneuropeArthur
The command in inventor selves.
You don't use coding to do the export.
Could you make a movie to see what happens.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 14 of 17
Log0ut
Yes, i dont use coding to do export.
Everything works as it must. Only problem is that images don't show up in DWG
Message 15 of 17
Log0ut
Anybody any idea?
Message 16 of 17
bradeneuropeArthur
could you share the template file (drawing file)?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 17 of 17
Log0ut
I attached template file
I don't believe that problem is template file, because in work computer same files works without problem
