Win11?
Win11?
Log0ut
837 次查看
16 条回复
1 条消息(共 17 条)
Win11?
Log0ut
Hi
I'm using follow code to generate PDF from drawings:
 '------start of iLogic-------
oPath = ThisDoc.Path
doc = IO.Path.GetFileName(ThisDrawing.ModelDocument.FullFileName)
oFileName = ThisDoc.FileName(False) 'without extension
oRevNum = iProperties.Value(doc, "Custom", "rev")
oProduct = iProperties.Value(doc, "Custom", "toode")
oCurDate = iProperties.Value("Status", "Checked Date")
oPDFAddIn = ThisApplication.ApplicationAddIns.ItemById _
("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
oDocument = ThisApplication.ActiveDocument
oContext = ThisApplication.TransientObjects.CreateTranslationContext
oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
oOptions = ThisApplication.TransientObjects.CreateNameValueMap
oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
'get PDF target folder path
oFolder = Left(oPath, InStrRev(oPath, "\"))
'Check for the PDF folder and create it if it does not exist
If Not System.IO.Directory.Exists(oFolder) Then
    System.IO.Directory.CreateDirectory(oFolder)
End If
 'Set the PDF target file name
oDataMedium.FileName = oFolder & "\" & oProduct & " - " & oRevNum & " - " & oCurDate &".pdf"
'Publish document
oPDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
'------end of iLogic-------
In work, win10, everything works. In home, win11, i get
this error:
Unspecified error (Exception from HRESULT: 0x80004005 (E_FAIL))
Has anybody have any idea, what causes this?
0 个赞
已接受的解答 (1)
838 次查看
16 条回复
回复 (16)
2 条消息(共 17 条)
bradeneuropeArthur
Have you show fileextensions on in win11?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
0 个赞
3 条消息(共 17 条)
Log0ut
Are my file extensions showing in file explorer? yes
0 个赞
4 条消息(共 17 条)
bradeneuropeArthur
What message do you receive the last, if you use this coding?
MsgBox("1")
MsgBox("2")
MsgBox("3")
MsgBox("4")
MsgBox("5")
MsgBox("6")
MsgBox("7")
MsgBox("8")
MsgBox("9")
MsgBox("10")
MsgBox("11")
MsgBox("12")
	MsgBox("13")
End If
oDataMedium.FileName = oFolder & "\" & oProduct & " - " & oRevNum & " - " & oCurDate & ".pdf"
MsgBox("14")
'Publish document
MsgBox("15")
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
0 个赞
5 条消息(共 17 条)
Log0ut
14, error in line 42
0 个赞
6 条消息(共 17 条)
bradeneuropeArthur
test if the add-in is loaded.
Do you receive a true message?
MsgBox("1")
MsgBox("2")
'oRevNum = iProperties.Value(doc, "Custom", "rev")
MsgBox("3")
'oProduct = iProperties.Value(doc, "Custom", "toode")
MsgBox("4")
MsgBox("5")
Dim oPDFAddIn As Inventor.ApplicationAddIn = ThisApplication.ApplicationAddIns.ItemById _
MsgBox("6")
MsgBox("7")
MsgBox("8")
MsgBox("9")
MsgBox("10")
MsgBox("11")
MsgBox("12")
	MsgBox("13")
End If
MsgBox("14")
'Publish document
MsgBox (oPDFAddIn.Activated)
MsgBox("15")
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
0 个赞
7 条消息(共 17 条)
Log0ut
Yes, true
0 个赞
8 条消息(共 17 条)
bradeneuropeArthur
已接受的解答
Test the date-string:
Does it contain non allowed characters like "/"?
MsgBox("1")
MsgBox("2")
MsgBox("3")
MsgBox("4")
MsgBox (oCurDate.ToString)
MsgBox("5")
Dim oPDFAddIn As Inventor.TranslatorAddIn = ThisApplication.ApplicationAddIns.ItemById _
MsgBox("6")
MsgBox("7")
MsgBox("8")
MsgBox("9")
MsgBox("10")
MsgBox("11")
MsgBox("12")
	MsgBox("13")
End If
MsgBox(oFolder & "\" & oProduct & " - " & oRevNum & " - " & oCurDate & ".pdf")
MsgBox("14")
'Publish document
MsgBox("15")
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
9 条消息(共 17 条)
Log0ut
That was it- changing date format, solved the problem. Thank you!
10 条消息(共 17 条)
Log0ut
I also have another similar problem- if i export drawings to dwg, attached images shows like that:
At work converting works as it must be, using same drawing
0 个赞
11 条消息(共 17 条)
bradeneuropeArthur
Can you share that code too?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
0 个赞
12 条消息(共 17 条)
Log0ut
I'm using File-Export-Export to DWG option
0 个赞
13 条消息(共 17 条)
bradeneuropeArthur
The command in inventor selves.
You don't use coding to do the export.
Could you make a movie to see what happens.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
0 个赞
14 条消息(共 17 条)
Log0ut
Yes, i dont use coding to do export.
Everything works as it must. Only problem is that images don't show up in DWG
0 个赞
15 条消息(共 17 条)
Log0ut
Anybody any idea?
0 个赞
16 条消息(共 17 条)
bradeneuropeArthur
could you share the template file (drawing file)?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
0 个赞
17 条消息(共 17 条)
Log0ut
I attached template file
I don't believe that problem is template file, because in work computer same files works without problem
0 个赞
