Why Inventor API opens every time the same Inventor Version
Hello guys,
I installed on my machine Inventor 2019 and Inventor 2021. At the moment I am writing a small Inventor API test and I wanna figure out why Inventor API opens every time Inventor 2019 by using this code:
Type invtype = System.Type.GetTypeFromProgID("Inventor.Application");
var inventorApplication = System.Activator.CreateInstance(invtype) as Inventor.Application;
 It opens also 2019 even I register the Inventor 2021 as default by opening it and approving the prompt message about reregistering Inventor to 2021 version. The reason why I am doing the test is, I want to figure out how to open a specific Inventor Version with Iventor API.
bradeneuropeArthur
If you make the reference in the app to the 2021 version it should not open the 2019 version anymore!
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Thank you for answering. How I should do the reference to the 2021 version?
I mean in the C# Code.
bradeneuropeArthur
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
