iLogic Rule to check scale in drawing
gildas.lincot
Message 1 of 9
gildas.lincot
Hi everyone!
I'm looking for to create an simple ilogic rule to check in a drawing if the scale of flat pattern view is the same of the sheet view.
Is any one can help me to find information about flat pattern view ? is there a parameter or something like that to find directly or not the scale of a flat pattern view ?
Thanks for you help!
Sorry for my english...
Salut!
Replies (8)
Message 2 of 9
WCrihfield
I'm not really sure about what scale your wanting to check the Flat Pattern View's scale to, because the sheet doesn't really have a scale property, only the views.  But here is a fairly simple iLogic rule that will find any FlatPatternView within the active sheet of your drawing, and display its name, its Scale, its ScaleString, and whether or not it is inheriting its scale from a base view.
If ThisApplication.ActiveDocumentType <> DocumentTypeEnum.kDrawingDocumentObject Then
	MsgBox("This rule '" & iLogicVb.RuleName & "' only works for Drawing Documents.",vbOKOnly, "WRONG DOCUMENT TYPE")
	Return
Dim oDDoc As DrawingDocument = ThisDrawing.Document
Dim oSheet As Inventor.Sheet = oDDoc.ActiveSheet
For Each oView As DrawingView In oSheet.DrawingViews
	If oView.IsFlatPatternView Then
		MsgBox("View Name = " & oView.Name & vbCrLf & _
		"View.Scale (Double) = " & oView.Scale.ToString & vbCrLf & _
		"View.ScaleString = " & oView.ScaleString & vbCrLf & _
		"View.ScaleFromBase = " & oView.ScaleFromBase, vbOKOnly, " ")
Next
If this solved your problem, or answered your question, please click ACCEPT SOLUTION.
Or, if this helped you, please click 'LIKE' 👍.
If you have time, please... Vote For My IDEAS 💡and Explore My CONTRIBUTIONS
Inventor 2021 Help | Inventor Forum | Inventor Customization Forum | Inventor Ideas Forum
Wesley Crihfield
(Not an Autodesk Employee)
Message 3 of 9
@gildas.lincot  Are you refering to the scale required in the title block?  I've modified the code of @WCrihfield .
	Return
		If oView.Scale <> 1 / 2 Then 'If view scale is not equal to 1/2 (as required), Then
			oView.Scale = 1 / 2		 'Set to 1/2 as required
	Else
		MsgBox("No Flat Pattern View Found.")
Next
Message 4 of 9
gildas.lincot
Thanks for your help!
"I'm not really sure about what scale your wanting to check the Flat Pattern View's scale to, because the sheet doesn't really have a scale property, only the views. "
I understand what you mean and it's right. In fact i would check if the flat pattern view scale is the same as the first view sacle of the sheet. If it's not, a message box appear to say "the scale of flat pattern view is not good".
I will try to work on it today, if i've got time...
Salut !
Message 5 of 9
Message 6 of 9
WCrihfield
So you are wanting something like this then?:
	Exit Sub
Dim oViews As DrawingViews = oSheet.DrawingViews
Dim o1stViewScale As Double = oViews.Item(1).Scale
Dim i As Integer
For i = 2 To oViews.Count
	If oViews.Item(i).IsFlatPatternView Then
		If oViews.Item(i).Scale <> o1stViewScale Then
			MsgBox("The 'Scale' of the Flat Pattern View named " & oViews.Item(i).Name & vbCrLf & _
			"does not match the Scale of the first view.", vbOKOnly + vbExclamation, " ")
Next
Wesley Crihfield
Message 7 of 9
gildas.lincot
Thanks for your help, here it's the rule i've create today:
	Return
Dim BonneEch As Decimal
Dim i As Integer
BonneEch=o1stViewScale
Next
		If oView.Scale.ToString <> o1stViewScale Then
		Response = MessageBox.Show("Souhaitez vous corriger ?", "Mauvaise Echelle de la Mise à Plat", MessageBoxButtons.YesNo, MessageBoxIcon.Question, MessageBoxDefaultButton.Button1)
		If Response = vbYes Then
		oView.Scale = BonneEch
		Else
		MessageBox.Show("A VOS RISQUES ET PERILS !", "ALORS ?", MessageBoxButtons.OK, MessageBoxIcon.Warning, MessageBoxDefaultButton.Button1)
Next
It's working well, perhaps it can be optimised...
Salut!
Message 8 of 9
NachoShaw
I did something similar a few years ago and the best approach back then was to check the flat pattern scale against the first base view scale. The view scale & the sheet scale can at times be different so if you need to make sure flat pattern scale matches the base view scale, compare them both.
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
Message 9 of 9
Charlies_3D_T
@WCrihfield
I implemented your rule but for some strange reason it does nothing. I just pasted it. Any idea what i could check? But i think i know why. The initial view scale was took from the flat pattern. And then we compare it to a flat pattern scale. But i have placed a base view on the drawing after i made the flat pattern and this has an other scale so it's not checking that.
Is it possible to add this also that he check every scale on the drawing?
