Use Ilogic rules to change diameter av threaded holes.
Hello everybody,
I have a standard beam with some standard threaded holes already in place. I can control the placement of the holes via parameter. But I would like to be able to changes all the holes from say M10 to M12 by just changing a parameter.
Is there a way to do that with a rule? A normal holes shows in the parameter list but not a threaded hole.
All tips are welcome.
Thanks Toon
Stay save.
FINET_Laurent
Maybe this helps ?
https://forums.autodesk.com/t5/inventor-customization/ilogic-change-hole-with-thread/td-p/9018321
FINET L.
If this post solved your question, please kindly mark it as "Solution"
If this post helped out in any way to solve your question, please drop a "Like"
@LinkedIn     @JohnCockerill
thanks, that helped
