Why does this code fail when I refresh the file after move it?
Darkforce_the_ilogic_guy
Advisor Advisor
I have a code that work fine on save .  But if I move a file and refresh the file  , It trigger the before save ilogic code and  it fail to run
oBOM.ImportBOMCustomization(sPathFile)
If i do a  normal save. If work ok . why does it fail   and is there a way to fix it without making Try Cathc as I have done in the code now
Sub main()
Dim oDoc As Document = ThisDoc.Document
If oDoc.DocumentType <> DocumentTypeEnum.kAssemblyDocumentObject Then Exit Sub
Dim oADoc As AssemblyDocument = oDoc
Dim oBOM As BOM = oADoc.ComponentDefinition.BOM
Dim sPathFile As String = "C:\Working Folder\CAD\Kallesoe\Kallesoe iLogic\UpdateBOMSetup\BOMSetting.xml"
Try
Catch
	Logger.Error("This fail when update files in iam after have move it in vault")
End Try
End Sub
bradeneuropeArthur
On which Event does the code run.
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
bradeneuropeArthur
Because the file is ReadOnly After moving Checkin to the Vault.
Sub main()
Dim fio As New System.IO.FileInfo(oDoc.FullFileName)
If fio.IsReadOnly = False Then
	MsgBox ("nro")
Else
MsgBox ("ro")
End If
End Sub
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
the ilogic run on the iam, that it is a part of , not the have been move. In may test the iam file was not check in to vault jet, but the file that was move was a check into vault
Have a look at my first question about what event the code is in!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
it is before save document
This is the error that popup if I dont use the Try and Catch
Darkforce_the_ilogic_guy_0-1710340547491.pngDarkforce_the_ilogic_guy_1-1710340547515.png
