why are ilogic code that is in Onsave trigger Running when open old assambly ?
Darkforce_the_ilogic_guy
Advisor Advisor
I have a code that need to run when the user is saving .. but for some unknow reason it somthing run when open an old drawing. is there a way to stop this ?
DRoam
Is the code that's being executed within the assembly you're opening itself, or within one of its component files? Have you performed some testing to make absolutely certain it's the on-save trigger that's triggering the rule?
dg2405
Do you use Vault?
it is an extranal rule that should only run on save
yes I use vault pro 2020
DRoam
Please turn on rule tracing by opening an iLogic rule and setting the Log Level to Trace:
Then open your assembly and copy/paste what's shown in the iLogic logger. If you don't have it open you can get to it here:
It should look something like this:
GUID-9ED68AD0-805A-462A-B801-78672EEF7C1D
