ilogic Delete unresolved views in an drawing
qkrtkddud
qkrtkddud
I want to make ilogic that deletes uninterpreted sheets from drawing at once. Is it possible?
This code should remove all unresolved views and parts lists in Active Sheet
Dim oDoc As DrawingDocument = ThisDoc.Document
Dim oSheet As Sheet = oDoc.ActiveSheet
Dim oView As DrawingView
Dim oPartsList As PartsList
For Each oView In oSheet.DrawingViews
	If oView.ReferencedFile.DocumentFound = False Then oView.delete
	Next
For Each oPartsList In oSheet.PartsLists
	If oPartsList.ReferencedFile.DocumentFound = False Then oPartsList.delete
	Next
MichaëlStienstra
Small arrangement. If No unresolved views are found an message box will pop up.
	If oView.ReferencedFile.DocumentFound = False Then oView.Delete
	Next
	oPartsList.Delete
Else
	MessageBox.Show("No unresolved views found", "Put in message box title")
	Next
