Waht dll to copy to clients?
i made my first api, but in the compile folder there are many dlls. In particular 2 that i did not add myself: autodesk.inventor.interop.dll and stdole.dll
Am I right in the asusmption that those two files will be present on every client computer, so all i need to copy over is the addin dll and the .addin file?
Thanks!
bradeneuropeArthur
1) Build Project;
 2) Copy add-in *.dll file to one of following locations:
  Inventor <InstallPath>\bin\ folder
 3) Copy.addin file to one of following locations:
  a) Inventor Version Dependent
  Windows :
   C:\Documents and Settings\All Users\Application Data\Autodesk\Inventor ####\Addins\
  Windows:
   C:\ProgramData\Autodesk\Inventor ####\Addins\
  b) Inventor Version Independent
  Windows:
   C:\Documents and Settings\All Users\Application Data\Autodesk\Inventor Addins\
  Windows:
   C:\ProgramData\Autodesk\Inventor Addins\
  c) Per User Override
  Windows:
   C:\Documents and Settings\<user>\Application Data\Autodesk\Inventor ####\Addins\
  Windows7/Vista:
   C:\Users\<user>\AppData\Roaming\Autodesk\Inventor ####\Addins\
 4) Startup Inventor, the AddIn should be loaded
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
