Announcements
Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
Convert Thumbnail to image
Hello
the Thumbnail is in IPictureDisp format, and the picturebox requires an image.
How can it be converted?
The sugestion found on the fourms to use VB6 does not seem to work anymore. (removed because obsolete, and not compatible with 64 bit system)
In the addin template there is the image converter that converts from image to IPictureDisp but not the inverse.
Thank you!
Solved with this code:
Public NotInheritable Class IPictureDispConverter : Inherits System.Windows.Forms.AxHost
        Private Sub New()
            MyBase.New("")
        End Sub
        Public Shared Function ImageToPictureDisp(image As Image) As IPictureDisp
            Try
                Return DirectCast(GetIPictureDispFromPicture(image), IPictureDisp)
            Catch ex As Exception
                'Add error message or logging here if desired.
                'Handle the conversion error by simply returning Nothing.
                Return Nothing
            End Try
        End Function
        Public Shared Function PictureDispToImage(pictureDisp As IPictureDisp) As Image
            Try
                Return GetPictureFromIPicture(pictureDisp)
                Return Nothing
            End Try
        End Function
    End Class
