Visible Inventor Drawings - Vault Check In
Hi Guys,
I need to check in the multiple drawing files into vault by default macros in inventor.
For that, I tried using with the below code.
Sub CheckInMultipleOpenDrawings()
Dim oDoc As Inventor.Document
For Each oDoc In ThisApplication.Documents.VisibleDocuments
If oDoc.DocumentType <> kDrawingDocumentObject Then
GoTo NextDoc
ElseIf oDoc.DocumentType = kDrawingDocumentObject Then
oDoc.Activate
oDoc.Save
Set ControlDefinition = ThisApplication.CommandManager.ControlDefinitions.Item("VaultCheckinTop")
ControlDefinition.Execute2 (True)
oDoc.Close
NextDoc:
Next
MsgBox "Checked-in the drawings"
End Sub
While using the above code, it will checking in only first and last file. Not working for all the opened drawing files.
For example , If i opened 5 drawings (Drawing number from 101 , 102, 103, 104 & 105)
Only 101 & 105 are getting checked in.
If u have any ideas to check all drawings..
Please suggest..
Thanks in advance..
@JhoelForshav @CGBenner @WCrihfield @Anonymous @Cadmanto @L.Greft @bradeneuropeArthur
