Visible Inventor Drawings - Vault Check In
SPALANIAPPANTN47S
SPALANIAPPANTN47S
Hi Guys,
I need to check in the multiple drawing files into vault by default macros in inventor.
For that, I tried using with the below code.
Sub CheckInMultipleOpenDrawings()
Dim oDoc As Inventor.Document
For Each oDoc In ThisApplication.Documents.VisibleDocuments
If oDoc.DocumentType <> kDrawingDocumentObject Then
GoTo NextDoc
ElseIf oDoc.DocumentType = kDrawingDocumentObject Then
oDoc.Activate
oDoc.Save
Set ControlDefinition = ThisApplication.CommandManager.ControlDefinitions.Item("VaultCheckinTop")
ControlDefinition.Execute2 (True)
oDoc.Close
End If
NextDoc:
Next
MsgBox "Checked-in the drawings"
End Sub
While using the above code, it will checking in only first and last file. Not working for all the opened drawing files.
For example , If i opened 5 drawings (Drawing number from 101 , 102, 103, 104 & 105)
Only 101 & 105 are getting checked in.
If u have any ideas to check all drawings..
Please suggest..
Thanks in advance..
@JhoelForshav @CGBenner @WCrihfield @Anonymous @Cadmanto @L.Greft @bradeneuropeArthur
bradeneuropeArthur
Have you tried this:
GoTo NextDoc
oDoc.Activate
oDoc.Save
oDoc.Close
End If
NextDoc:
Next
End Sub
Otherwise.
Can you let me show the:
Vault options in inventor each dialog and settings, a screenshot please!
A screenshot of the vault browser for each drawing that keeps checked out.
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
