viewcube
viewcube
viewcube
In Inventor2018 I made a sketch on x,y-plane, The extrude of it is in the graphic screen in the vertical position (z-axis)
In Inventor2019 the extrude of a sketch on x,y-plan shows in the graphic screen the y-axis in the vertical position. However I want the z-axis in the vertical position, just as in Inventor2018. Which setting have I to change?
bradeneuropeArthur
Take a look in the document settings of the file. Here you can find something...
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
How can I redefine the home view and get the new home view in the template file?
dgreatice
1. When you create New File, ipt/iam, are you use default template?
2. Or use you own file template, base on default template (Save As Template)?
3. Did you set view cube? Default when you select "Front View" are same orientation view with XY plane.
How to change:
select "Bottom View" as showed, right click in viewcube > Set Current View as > Front
Don't forgot to Save as Template
Please use the ACCEPT AS SOLUTION or KUDOS button if my Idea helped you to solve the problem.
Autodesk Inventor Professional Certified 2014
bradeneuropeArthur
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
bradeneuropeArthur
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
