View Label Left Text Alignment
jR0sal3s
jR0sal3s
Could anybody help with Macro coding so if i run it, the text in the view label would align to the left and to the left most of the drawing view as well?
And where could i find the syntax on macro coding?
Looking forward, Thanks a lot..
jR
MechMachineMan
THe top right corner of your inventor program... Cick the question mark drop down, and find the "Programming Help"
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
jR0sal3s
Yes, i did that but im just beginning to learn it...and could not make anything work...so i've research to find the following, cut and paste to the macro but wont run though...is there anyway to convert the syntax to make it readable in the macro..?.(i'd like to understand the syntax in the macro works against other languages)
Dim oDoc As DrawingDocument = ThisDoc.Document
Dim oSheets As Sheets = oDoc.Sheets
Dim oView As DrawingView
For Each oSheet In oSheets
    For Each oView In oSheet.DrawingViews
        If Not oView.Label.HorizontalJustification = HorizontalTextAlignmentEnum.kAlignTextLeft Then
    Next
Next
MechMachineMan
If it contains "set", it is vba and should be used in the Macro Editor. If
it doesn't, just use it in a rule.
Justin K
jR0sal3s
yes it runs in a rule, but would you be able to convert it to a macro syntax?..i d like to learn how it is being translated..and from there maybe I will develop my own..thanks
MechMachineMan
Yes. Add "Set" in front of lines with =.
Justin K
jR0sal3s
finally..so, thanks for giving me the clue! and here it goes...
Dim _Doc As DrawingDocument
_Doc = _invApp.ActiveDocument
Dim _Sheets As Sheets
_Sheets = _Doc.Sheets
Dim _View As DrawingView
For Each _Sheet In _Sheets
For Each _View In _Sheet.DrawingViews
If Not _View.Label.HorizontalJustification = HorizontalTextAlignmentEnum.kAlignTextLeft Then
Next
Next
jR
