View Label customization
I would like to have an Ilogic rule for this:
I have a big assembly with some subassy.
I usually make an only drawing for all.
Let say the first sheet has the big assy with the BOM.
The 2nd sheet has the Subassy A drawing, its BOM and its parts drawings.
The Ilogic rule should populate automatically the parts views with labels:
Part number
thickness (for sheet metal parts) Material
Quantity in this Subassembly
Total quantity for the job.
If it is possible avoid to have the label for the flat part view.
If it is possible add the same for the subassembly view:
Part number
Quantity for job
The Ilogic rule should work just for the active sheet.
Thank you.
