Rule to suppress features containg certain words...
I'm sure this has been address before..but of course I can't make it work.  I need to have a global rule that will suppress any feature containing the string "control_side" .
I've tried this code I found elsewhere & modified:
SyntaxEditor Code Snippet
myparam = "control_side"
Dim oDoc as PartDocument
oDoc = ThisApplication.ActiveDocument
Dim oFeature As PartFeature
For Each oFeature In oDoc.ComponentDefinition.Features
  If oFeature.Name.ToUpper.Contains(myparam.ToUpper) Then
    oFeature.Suppressed = True
    oDoc.Update
Next
...but no dice.  Can someone get me over the finish line?  Thanks in advance!
perrysc
Try this.
Dim myparam As String = "control_side"
Dim oFeatureName As String For Each oFeature In oDoc.ComponentDefinition.Features oFeatureName = UCase(oFeature.Name)
If oFeatureName.Contains(UCase(myparam)) Then oFeature.Suppressed = True oDoc.Update End If Next
Thanks for the reply, but I get these error messages:
Error in rule: suppress_control_sides, in document: testing divert to right.iam
Unable to cast COM object of type 'System.__ComObject' to interface type 'Inventor.PartDocument'. This operation failed because the QueryInterface call on the COM component for the interface with IID '{29F0D463-C114-11D2-B77F-0060B0F159EF}' failed due to the following error: No such interface supported (Exception from HRESULT: 0x80004002 (E_NOINTERFACE)).
perrysc
Oh, you're running the rule in an assembly? The solution is easy then.
Dim oDoc as AssemblyDocument
    oDoc.Update
Next
Well that got rid of the errors, and yes, I totally see how you switched from Part to Assembly.  Duh on me.  However, the features are still not switching off.  I've attached files that have the assembly/parts in it with the names as they appear in my formal project files.  Prolly shoulda done that right away, again, Duh on me.  If you have time I'd appreciate the extra help in error-checking.  Thanks again!
perrysc
Ah, I see, you want to affect features inside of part files from an assembly. Okay, I've written a new rule that does what you want it to. This rule only goes one level down, however, so it's not going to get a part in a subassembly located in the assembly the rule is run it. I wasn't sure if you needed that functionality.
Sub Main()
	Dim oAsmDoc As AssemblyDocument = ThisApplication.ActiveDocument
	Dim oAsmDef As AssemblyComponentDefinition = oAsmDoc.ComponentDefinition
	Dim oUniqueOccurrencesFileNames As New List(Of String)()
	Dim oUniqueOccurrencesDefs As ObjectCollection = ThisApplication.TransientObjects.CreateObjectCollection
	For Each oThing As ComponentOccurrence In oAsmDef.Occurrences
		If Not oUniqueOccurrencesFileNames.Contains(oThing.Definition.Document.FullFileName) Then
			oUniqueOccurrencesFileNames.Add(oThing.Definition.Document.FullFileName)
			oUniqueOccurrencesDefs.Add(oThing.Definition)
	Next
	Dim oStringToFilter As String = "Control_Side" ''' Make this whatever
	For Each oThing As ComponentDefinition In oUniqueOccurrencesDefs
		For Each oFeature As PartFeature In oThing.Features
			If oFeature.Name.ToUpper.Contains(oStringToFilter.ToUpper) Then
		Next
	Next
	InventorVb.DocumentUpdate()
End Sub
Woah...
Excellent!  That works great, just tried it!
