iLogic Drawing View File Type Identification
chrisw01a
chrisw01a
Hey guys.
This should be an easy one for you in the know...
Simply trying to determine if a drawing view is an assembly or part.
This code is skipping something because it always uses the first solution in the IF statement.
See red code...
'iterate through a IDW and add "Part Number, Total Part Qty" to the base view labels
Dim oDoc As DrawingDocument = ThisDoc.Document
Dim oModel = ThisDoc.ModelDocument
Dim oSheets As Sheets = oDoc.Sheets
Dim oSheet As Sheet
Dim oViews As DrawingViews
Dim oView As DrawingView
For Each oSheet In oSheets
	oViews = oSheet.DrawingViews
	For Each oView In oViews
		'oView.ViewType = DrawingViewTypeEnum.kDetailDrawingViewType _
		'oView.ViewType = DrawingViewTypeEnum.kSectionDrawingViewType
		If oView.ViewType = DrawingViewTypeEnum.kStandardDrawingViewType Then
		'if viel label is hidden, unhide
		oView.ShowLabel = True
			Try
			'get the property ID for these custom iProperties from the model referenced by the view
			o_iPropID_1 = oModel.PropertySets.Item("User Defined Properties").Item("TotalPartQty").PropId
			o_iPropID_2 = oModel.PropertySets.Item("User Defined Properties").Item("My_iProp_2").PropId
			Catch
			'here you could add a message that one or more of the custom iProperties were not found
			End Try
			Try
			'format the custom iproperty string and add the property ID
			oPartQty = "<Property Document='model' PropertySet='User Defined Properties' " _
			& "Property='TotalPartQty' FormatID='{D5CDD505-2E9C-101B-9397-08002B2CF9AE}' PropertyID='" _
			& o_iPropID_1 & "'>TotalPartQty</Property>"
			''format the custom iproperty string and add the property ID
			'oString2 = "<Property Document='model' PropertySet='User Defined Properties' " _
			'& "Property='My_iProp_2' FormatID='{D5CDD505-2E9C-101B-9397-08002B2CF9AE}' PropertyID='" _
			'& o_iPropID_2 & "'>My_iProp_2</Property>"
			'format the built in iproperty string and add the property ID
			oPartNumber = "<StyleOverride Bold='false' Underline='false'><Property Document='model' PropertySet='Design Tracking Properties' Property='Part Number' FormatID='{32853F0F-3444-11D1-9E93-0060B03C1CA6}' PropertyID='5'>PART NUMBER</Property></StyleOverride>"
			'oStockNumber = "<Br/><StyleOverride Bold='false' Underline='false'><Property Document='model' PropertySet='Design Tracking Properties' Property='Stock Number' FormatID='{32853F0F-3444-11D1-9E93-0060B03C1CA6}' PropertyID='5'>STOCK NUMBER</Property></StyleOverride>"
			'oStringScale = "<StyleOverride FontSize='0.2'> FLAT VIEW (<DrawingViewScale/>)</StyleOverride>"
			'oPartNumber = "<Br/><StyleOverride Underline='False' FontSize='0.2'>PART ID:    <Property Document='model' PropertySet='Design Tracking Properties' Property='Part Number' FormatID='{32853F0F-3444-11D1-9E93-0060B03C1CA6}' PropertyID='5'>PART NUMBER</Property></StyleOverride>"
			'oStringProfile = "<Br/><StyleOverride FontSize='0.2'>PROFILE:   <Property Document='model' PropertySet='Design Tracking Properties' Property='Description' FormatID='{32853F0F-3444-11D1-9E93-0060B03C1CA6}' PropertyID='29'>DESCRIPTION</Property></StyleOverride>"
			oStringMaterial = "<StyleOverride Underline='False'><Property Document='model' PropertySet='Design Tracking Properties' Property='Material' FormatID='{32853F0F-3444-11D1-9E93-0060B03C1CA6}' PropertyID='20'>PART NUMBER</Property></StyleOverride>"
			'oStringAuth = "<Br/><StyleOverride Underline='False' FontSize='0.2'>QTY:        <Property Document='model' PropertySet='Design Tracking Properties' Property='Authority' FormatID='{32853F0F-3444-11D1-9E93-0060B03C1CA6}' PropertyID='5'>AUTHORITY</Property></StyleOverride>"
				'add the custom iproperties to the view label
				'oView.Label.FormattedText = "<DrawingViewName/><Br/>" & oString1 & oString2
				'Here Is a list Of all Of the the DocumentType enumerators available In the API:
				'kUnknownDocumentObject
				'kPartDocumentObject
				'kAssemblyDocumentObject
				'kDrawingDocumentObject
				'kPresentationDocumentObject
				'kDesignElementDocumentObject
				'kForeignModelDocumentObject
				'kSATFileDocumentObject
				'kNoDocument
				'DETERMINE MODEL TYPE
				'If oModel.DocumentType = kPartDocumentObject  Then
				oView.Label.FormattedText = oPartNumber & "<Br/>" & oStringMaterial & "<Br/>" & oPartQty & " RQD "
				'Else
				'oView.Label.FormattedText = oPartNumber & "<Br/>" & oPartQty & " RQD "
				'End If
			Catch
			'do nothing if error
			End Try
	Next
Next
salariua
I think you need to get type of model from each view rather than setting it globally at the beginning of the code. On some drawings, you could have both assemblies and parts.
If oModel.DocumentType = Inventor.DocumentTypeEnum.kPartDocumentObject  Then
Adrian S.
blog.ads-sol.com
AIP2012-2020 i7 6700k AMD R9 370
Did you find this reply helpful ?
If so please use the Accepted Solutions or Like button - Thank you!
chrisw01a
I briefly considered that but the code has been working as it is for putting
the view labels on.
I will look into this. Thank you.
Use this instead of oModel
Dim oViewModelDoc As Document
oViewModelDoc = oView.ReferencedDocumentDescriptor.ReferencedDocument
If oViewModelDoc.DocumentType = kPartDocumentObject Then
Else
chrisw01a
Thank you for your help.
Chris
