VBA text box fill Properties
j.romo
j.romo
Hello guys
Here I am struggling again
I mannaged to make a button to create some iproperties in VBA in a user form, but now I want to have some Textboxes to fill the value of the iproperties
but I can¡t get arroud it
 some hel would be great
the custom property is telephone
thanks
Private Sub TextBox1_Enter()
  Dim invDoc As Document
    Set invDoc = ThisApplication.ActiveDocument
    ' Get the design tracking property set.
    Dim invDesignInfo As PropertySet
    Set invDesignInfo = invDoc.PropertySets.Item("Design Tracking Properties")
    ' Get the part number property.
    Dim invPartNumberProperty As Property
    Set invPartNumberProperty = invDesignInfo.Item("TELEPHONE")
 invPartNumberProperty.Value
End Sub
b_sharanraj
Hi @j.romo
Please look into the below pic from the Toolbox Controls you can add a Textbox to Userform 🙂
Regards
B.Sharan Raj
MechMachineMan
It also helps if you access the proper property set: "Inventor User Defined Properties" instead of "Design Tracking Properties".
See this blog: http://modthemachine.typepad.com/my_weblog/2010/02/accessing-iproperties.html
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
j.romo
Ifound out how to do it
I Had to call the textbox1.value to insert the value typed in the textbox to the iproperty the code is like this.
the link is very helpfull justin...
Private Sub CommandButton2_Click()
    ' Get the active document.
    Dim doc As Document
    Set doc = ThisApplication.ActiveDocument
    ' Get the custom property set.
    Dim customPropSet As PropertySet
    Set customPropSet = doc.PropertySets.Item( _
    "Inventor User Defined Properties")
    ' Get the property named "TELEFONO".
    Dim customProp As Property
    Set customProp = customPropSet.Item("TELEFONO")
    ' Display the value of the iProperty.
    'MsgBox "TELEFONO = " & customProp.Value
     ' Set the value of the property.
    customProp.Value = TextBox1.Value
End Sub
