VBA Make a Hexagone
VBA Make a Hexagone
VBA Make a Hexagone
Hi, and thanks for reading!
Private Function buildPoligone(oparamD) As SketchBlock
    Dim SelectedPoint As Inventor.SketchPoint
    Set SelectedPoint = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kSketchPointFilter, "Select the point...")
    ThisApplication.CommandManager.StopActiveCommand
    ' Connect to a running instance of Inventor.
    Dim invApp As Inventor.Application
    Set invApp = ThisApplication
    'System.Runtime.InteropServices.Marshal.GetActiveObject
                                                '("Inventor.Application")
    ' Set a reference to the active sketch.
    Dim oSketch As PlanarSketch
    Set oSketch = ThisApplication.ActiveEditObject
    ' Get a reference to the TransientGeometry object.
    Dim tg As Inventor.TransientGeometry
    Set tg = invApp.TransientGeometry
    ' Get a reference to the SketchLines collection.
    Dim olines As Inventor.SketchLines
    Set olines = oSketch.SketchLines
    ' Get a reference to the SketchCircle collection.
    Dim oCircles As Inventor.SketchCircles
    Set oCircles = oSketch.SketchCircles
    Dim oCircle1 As Inventor.SketchCircle
    Set oCircle1 = oCircles.AddByCenterRadius(SelectedPoint, oparamD)
    oparamRi = oparamRi / 2
    oparamRc = oparamRi / (Math.Sqr(3) / 2)
    Dim oInscribedPoint As Inventor.SketchPoint
    Set oInscribedPoint = SelectedPoint
    oInscribedPoint.Geometry.X = SelectedPoint.Geometry.X - oparamRc
    oInscribedPoint.Geometry.Y = SelectedPoint.Geometry.Y
' Define inputs needed to rotate.
    Dim col As ObjectCollection
    Set col = ThisApplication.TransientObjects.CreateObjectCollection
    Call col.Add(oInscribedPoint)
    Dim i As Long
    Dim rotatePoint As Point2d
    Set rotatePoint = tg.CreatePoint2d(0, 0)
    rotatePoint.X = SelectedPoint.Geometry.X
    rotatePoint.Y = SelectedPoint.Geometry.Y
    Dim pi As Double
    pi = Atn(1) * 4
    Dim Angle As Double
    Angle = Me.Angle.Value * (pi / 180)
    For i = 1 To 6
    Dim colsub As ObjectCollection
    Set colsub = ThisApplication.TransientObjects.CreateObjectCollection
    colsub.Add (oSketch.RotateSketchObjects(col, rotatePoint, Angle + 60 * (i)))
    Next
    Dim oline As Inventor.SketchLine
    Dim StPoint As Object
    Set StPoint = colsub(1)
    Dim EnPoint As Object
    Set EnPoint = colsub(2)
    Set oline = olines.AddByTwoPoints(StPoint, EnPoint)
End Function
After so much pain with this problem, I still can t make a simple hexagone with VBA. Here the object collection (named "subcol") is not filling up (shun't I get 6 object in it?) .
Why does this synthaxe:
colsub.Item(i).Add (oSketch.RotateSketchObjects(col, rotatePoint, Angle + 60 * (i)))
..that seems to be used all over exemples, doesn t work in my case?
Also tryed the methode to make a hexagone directly without any succes...
 Dim oline1 As Inventor.SketchLine
    Set oline1 = olines.AddByTwoPoints(oInscribedPoint.Geometry.X, SelectedPoint
    Dim opoly As Inventor.Polyline2d
    Dim oSides As Long
    oSides = 6
    opoly = olines.AddAsPolygon(6, SelectedPoint, oInscribedPoint, True)
Any clues?
Ok, just simply how can I make a hexagone with VBA? I just can t make any working code for it. Feels awful!
I have aready all the coordonate setted up in formulas, but unable to do anything with it.
bradeneuropeArthur
Why don't you use the inventor command for this!?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
BrianEkins
Here's a little VBA example that uses the AddAsPolygon method to create a hexagon.
Public Sub CreateHexagon()
    Dim sk As sketch
    Set sk = ThisApplication.ActiveEditObject
    Dim tg As TransientGeometry
    Set tg = ThisApplication.TransientGeometry
    Dim results As SketchEntitiesEnumerator
    Set results = sk.SketchLines.AddAsPolygon(6, tg.CreatePoint2d(0, 0), tg.CreatePoint2d(6, 0), True)
End Sub
Brian Ekins
