VBA Library location
I'm working on a project of automatisation parts and assembly on the VBA editor on Inventor. The problem is that I can't find the library made on VBA for Inventor (for example, create geometry, extrusion, assembly etc). I've searched on Help (F1), but it is just a help based on classic VBA. So, where can I find the VBA Inventor library for this kind of using?
An other question, do you know how can I make the link between an excel file, and Inventor? (directly on Vba Editor).
Thanks!
bradeneuropeArthur
What do you mean with the library?
You mean your Company standards?
about the excel link:
Do you need to know how to do that with or without coding or both?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
I was meaning the functions etc that you can use to make a sketch, an extrusion etc, but I've just find it, thank you.
For the Excel, I was wondering how can I make a link between the excel and my vba sheet on Inventor (for example, to get a length on an excel to make an extrusion, or point coordinates...)
bradeneuropeArthur
See the picture:
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Thanks a lot!
