VBA - iProperty value
Jef_E
Jef_E
Hi there,
I'm trying to read a certain iProperty, so I can check if my part/assembly is a valid file to edit via code.
This is what i get, but when i'm debugging it kills me at:
oPropSet = oDoc.Item("Inventor Document Summary Information")
What do i need to change?
I also tried inserting this code instead of the text, same result.
{D5CDD502-2E9C-101B-9397-08002B2CF9AE}
My code:
 ' Get the active document.
Dim oDoc As Document
oDoc = _invApp.ActiveDocument
' Get a reference to the "Inventor Document Summary Information" PropertySet
Dim oPropSet As PropertySet
' Get the Category property.
Dim oCat As [Property]
oCat = oPropSet.Item("Category")
MsgBox(oCat.Value())
Thanks for the help!
Inventor 2013
Visual Studio 2010
Please kudo if this post was helpfull
Please accept as solution if your problem was solved
Inventor 2014 SP2
Jef_E
I found the error.
This:
Should be this:
oPropSet = oDoc.PropertySets.Item("Inventor Document Summary Information")
Code:
MsgBox(oCat.Value)
Inventor 2014 SP2
MechMachineMan
You are forgetting to call the collection in which the property set belongs to; a specific property set is not found directly on the document class, but instead within a PropertySets collection which belongs to the document;
ie;
ThisApplication.ActiveDocument.PropertySets.Item("Inventor Document Summary Information").Item("Category").Value
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Jef_E
Thanks for the reply, I had just found what was wrong 🙂 thanks anyway!
Inventor 2014 SP2
