VBA help
VBA help
VBA help
Hi
I found the below code at Mod the Machine , Thanks to Brian Ekins
http://modthemachine.typepad.com/my_weblog/2016/01/open-drawing-from-a-part-or-assembly.html
I do not know any think about VBA ,so help is needed
Because When running a debug it stops at:
Set partDoc = ThisApplication.ActiveDocument
Can anyone tell me if I am doing some think wrong or what is wrong
I use the VBA Editor in Inventor 2017
Public Sub FindDrawingTest()
    Dim partDoc As PartDocument
    ' Call the function to get the drawing.
    Dim drawingFilename As String
    drawingFilename = FindDrawingFile(partDoc)
    ' Display the result.
    If drawingFilename <> "" Then
        MsgBox "The drawing for """ & partDoc.fullFilename & """ was found: " & vbCr & drawingFilename
    Else
        MsgBox "No drawing was found for """ & partDoc.fullFilename & """"
End Sub
' Find the drawing for the specified part of assembly.
Private Function FindDrawingFile(PartOrAssemblyDoc As Document)
    Dim fullFilename As String
    fullFilename = PartOrAssemblyDoc.fullFilename
    ' Extract the path from the full filename.
    Dim path As String
    path = Left$(fullFilename, InStrRev(fullFilename, "\"))
    ' Extract the filename from the full filename.
    Dim filename As String
    filename = Right$(fullFilename, Len(fullFilename) - InStrRev(fullFilename, "\"))
    ' Replace the extension with "dwg"
    filename = Left$(filename, InStrRev(filename, ".")) & "dwg"
    ' Find if the drawing exists.
    drawingFilename = ThisApplication.DesignProjectManager.ResolveFile(path, filename)
    ' Check the result.
    If drawingFilename = "" Then
        ' Try again with idw extension.
        filename = Left$(filename, InStrRev(filename, ".")) & "idw"
        ' Return the result.
            FindDrawingFile = drawingFilename
        Else
            FindDrawingFile = ""
    Else
End Function
tolgay.hickiran
If a PARTDOCUMENT is open on inventor this will work, you might be on an ASSEMBLYDOCUMENT while you are trying to work the code.
I'd recommend you to use DEBUG MODE, which can be started from F8 key on your keyboard in the VBA Editor.
Some worthwhile ideas
Copy Design should rename ilogic Rules too!
Why Nastran In-CAD doesn't have an SDK?IMPLEMENTED!
Tolgay Hickiran
Founding Partner
SignatureSignature
website
emailskypelinkedinyoutubeemail
MechMachineMan
As @tolgay.hickiran said...
    Dim Doc As Document
Set Doc = ThisApplication.ActiveDocument ' Call the function to get the drawing. Dim drawingFilename As String drawingFilename = FindDrawingFile(Doc) ' Display the result. If drawingFilename <> "" Then MsgBox "The drawing for """ & Doc.fullFilename & """ was found: " & vbCr & drawingFilename Else MsgBox "No drawing was found for """ & Doc.fullFilename & """" End If End Sub ' Find the drawing for the specified part of assembly. Private Function FindDrawingFile(PartOrAssemblyDoc As Document) Dim fullFilename As String fullFilename = PartOrAssemblyDoc.fullFilename ' Extract the path from the full filename. Dim path As String path = Left$(fullFilename, InStrRev(fullFilename, "\")) ' Extract the filename from the full filename. Dim filename As String filename = Right$(fullFilename, Len(fullFilename) - InStrRev(fullFilename, "\")) ' Replace the extension with "dwg" filename = Left$(filename, InStrRev(filename, ".")) & "dwg" ' Find if the drawing exists. Dim drawingFilename As String drawingFilename = ThisApplication.DesignProjectManager.ResolveFile(path, filename) ' Check the result. If drawingFilename = "" Then ' Try again with idw extension. filename = Left$(filename, InStrRev(filename, ".")) & "idw" ' Find if the drawing exists. drawingFilename = ThisApplication.DesignProjectManager.ResolveFile(path, filename) ' Return the result. If drawingFilename <> "" Then FindDrawingFile = drawingFilename Else FindDrawingFile = "" End If Else ' Return the result. FindDrawingFile = drawingFilename End If End Function
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Yes , It works when I have a part open.
But it only looks in the folder as the part , is it possible to make it look in may be two  preset different folders?
MechMachineMan
You could try this.
Modify oPathList as required.
Does not handling searching sub-folders; every directory must be listed explicitly.
    Dim Doc As Document
    Else
End Sub
    Dim oPathList As String(0 to 1)
    oPathList(0) = "PARENT"
    oPathList(1) = "D:\"
    oPathList(2) = "C:\"
    Dim opath As String
    opath = Left$(fullFilename, InStrRev(fullFilename, "\"))
    For j = 0 to UBound(oPathList)
	If oPathList(j) = "PARENT"
		path = opath
	else
		path = oPathList(j)
	End if
		Else
			Exit Function
	Else
		Exit Function
    Next
End Function
Justin K
Hi Justin
Thanks for Your reply
When I run your code I get this message
As I said earlier  ,I do not know anything about VBA , so I am lost
MechMachineMan
At least TRYING to learn something could get you somewhere... Google is a wonderful resource.
Fixed version included below:
    Dim Doc As Document
        ThisApplication.Documents.Open drawingFilename
    Else
End Sub
    Dim oPathList(0 To 2) As String
    Dim opath As String
    For j = 0 To UBound(oPathList)
        If oPathList(j) = "PARENT" Then
            Path = opath
        Else
            Path = oPathList(j)
        drawingFilename = ThisApplication.DesignProjectManager.ResolveFile(Path, filename)
            Else
                Exit Function
        Else
            Exit Function
    Next
End Function
Justin K
