VBA Events get disconnected after code crash
Majjek
Majjek
I'm busy with some events in VBA.
I've created an EventClass with 2 subs Connect and Disconnect to activate the Events.
There is 1 OnSaveDocument event present and it works perfect.
But when I'm working on other code, and during debugging it crashes, the Eventclass seems to get disconnected.
That means I have to reconnect to the EventClass again each time my code crashes.
How can I prevent this from happening?
Thanks in advance.
bradeneuropeArthur
By creating an add-in with ie VB.net.
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
chandra.shekar.g
Autodesk Support
Autodesk Support
@Majjek ,
To test crash, please share VBA code and make sure that files are non confidential.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
Majjek
Thanks for the answers guys.
I knew this would be one of the answers I'd receive Smiley Tongue.
Because I'm not very familiar with VB.Net and VS, I thought it would took me some time before I could create an add-in with events.
But a little search on the forums showed me that it wasn't that hard.
bradeneuropeArthur
Fully agree with that...
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
