VBA code to iLogic code - run before Save
Message 1 of 10
since we changed to IV16 yesterday, our Autosave VBA-Macro doesnt work.
I know, this is because of the changes made by Autodesk which bans the possibility to use those run before save macros.
So let me first explain what the macro was supposed to do:
It should automatically change the material, the Scale and some texts we use on our IDW drawings.
So since the Macro doesnt run when pressing the save button, i installed the MuM - iLogic run on save AddIn, which seems to be working.
I was able to implement the old code into the iLogic rulebrowser, but, as i expected, the code does not work.
Attached is a screenshot of the errors.
Further I have to say that I have absolutely NO expierence in programming, so i would like to ask if anyone of you will help me with this.
Kind regards, Thomas
Here is the code we used till yesterday with IV13:
Option Explicit
Private Function EE_FormatScale(ByVal S As Double) As String
  If S >= 1 Then
    If (10 * S Mod 10) = 0 Then
      EE_FormatScale = Format(S, "0") + ":1"
    Else
      EE_FormatScale = Format(S, "0.0") + ":1"
    End If
  Else
    If (10 * (1 / S) Mod 10) = 0 Then
      EE_FormatScale = "1:" + Format(1 / S, "0")
    Else
      EE_FormatScale = "1:" + Format(1 / S, "0.0")
    End If
  End If
End Function
Sub AutoSave()
    Call Massstab
    Call WieGezSpiegelbildlich
    Call WerkstoffZugewiesen
End Sub
Sub WerkstoffZugewiesen()
End Sub
Sub WieGezSpiegelbildlich()
On Error Resume Next
    Dim oDoc As Document
    Dim sName As String
    'Objekt herstellen
    Set oDoc = ThisApplication.ActiveDocument
    sName = Mid(GetFilename(ThisApplication.ActiveDocument.ReferencedDocuments.Item(1).FullDocumentName), 1, Len(ThisApplication.ActiveDocument.ReferencedDocuments.Item(1).FullDocumentName) - 6)
    sName = Mid(sName, 1, 11)
    'Füge Zeichenfolge ein
    oDoc.PropertySets("{D5CDD505-2E9C-101B-9397-08002B2CF9AE}").Item("Bauteilnummer").Value = sName & "01"
    oDoc.PropertySets("{D5CDD505-2E9C-101B-9397-08002B2CF9AE}").Item("Bauteilnummer gespiegelt").Value = sName & "02"
End Sub
Sub Massstab()
  Dim I, J, K As Integer
  Dim EE_MainScale, EE_TestScale As Double
  Dim EE_SiteScale(10) As Double
  Dim EE_Text As String
  Dim EE_Da As Boolean
  Dim EE_Prop As Property
  Dim EE_Objekt As Object
  'Objekt herstellen
  'Funktioniert nur, wenn Drawing und mindestens eine Ansicht vorhanden ist:
  If oDoc.DocumentType <> kDrawingDocumentObject Then Exit Sub
  If oDoc.ActiveSheet.DrawingViews.Count = 0 Then Exit Sub
    'Ermittle die Hauptansicht und Hauptmaßstab
    EE_MainScale = oDoc.ActiveSheet.DrawingViews(1).Scale
  'Ermittle weitere Ansichten
  J = 0
  For I = 1 To oDoc.ActiveSheet.DrawingViews.Count
    'Ermittle weitere Maßstäbe
    EE_TestScale = oDoc.ActiveSheet.DrawingViews(I).Scale
    'Prüfe, ob gleich hauptmaßstab
    If EE_TestScale <> EE_MainScale Then
      'Prüfe, ob schon als Nebenmaßstab vorhanden
      If J > 0 Then
        For K = 0 To J
          If EE_TestScale = EE_SiteScale(K) Then
            EE_TestScale = 0
            Exit For
          End If
        Next K
      End If
      If EE_TestScale <> 0 Then
        'Nimm in die Liste auf
        EE_SiteScale(J) = EE_TestScale
        J = J + 1
        'Die liste ist begrenzt...
        If J = 11 Then Exit For
      End If
    End If
  Next I
  EE_Text = EE_FormatScale(EE_MainScale)
  If J > 0 Then
    EE_Text = EE_Text + " ("
    For I = 0 To J - 1
      If (I > 0) And (I < 2) Then
        EE_Text = EE_Text + " "
      End If
      If (I > 1) Then
        EE_Text = EE_Text + ", "
      End If
      EE_Text = EE_Text + EE_FormatScale(EE_SiteScale(I))
    Next I
    EE_Text = EE_Text + ")"
  End If
  'Maßstab vorhanden?
  EE_Da = False
  For Each EE_Prop In oDoc.PropertySets("{D5CDD505-2E9C-101B-9397-08002B2CF9AE}") 'Benutzerdefiniert
    If EE_Prop.Name = "Massstab" Then
      EE_Da = True
      Exit For
    End If
  Next
  If EE_Da Then
    oDoc.PropertySets("{D5CDD505-2E9C-101B-9397-08002B2CF9AE}").Item("Massstab").Value = EE_Text
  Else
    oDoc.PropertySets("{D5CDD505-2E9C-101B-9397-08002B2CF9AE}").Add EE_Text, "Massstab"
  End If
End Sub
Public Function GetFilename(ByVal Path As String) As String
    GetFilename = Mid(Path, Len(GetPath(Path)) + 1, Len(Path) - Len(GetPath(Path)))
End Function
Public Function GetPath(ByVal Pfad As String) As String
    Dim I As Integer
    Dim iPos As Integer
    iPos = InStrRev(Pfad, "\", , vbBinaryCompare)
    GetPath = Mid(Pfad, 1, iPos)
End Function
Replies (9)
Message 2 of 10
Owner2229
Hi, try it now:
Option Explicit
Sub Main()
    Call Massstab
End Sub
  If S >= 1 Then
    Else
    End If
  Else
    Else
    End If
  End If
End Function
End Sub
    Dim sName As String
'Objekt herstellen oDoc = ThisApplication.ActiveDocument sName = Mid(GetFilename(oDoc.ReferencedDocuments.Item(1).FullDocumentName), 1, Len(ThisApplication.ActiveDocument.ReferencedDocuments.Item(1).FullDocumentName) - 6) sName = Mid(sName, 1, 11) 'Füge Zeichenfolge ein oDoc.PropertySets("{D5CDD505-2E9C-101B-9397-08002B2CF9AE}").Item("Bauteilnummer").Value = sName & "01" oDoc.PropertySets("{D5CDD505-2E9C-101B-9397-08002B2CF9AE}").Item("Bauteilnummer gespiegelt").Value = sName & "02" End Sub Sub Massstab() Dim I, J, K As Integer Dim EE_MainScale, EE_TestScale As Double Dim EE_SiteScale(10) As Double Dim EE_Text As String Dim EE_Da As Boolean Dim EE_Prop As Property Dim oDoc As Document Dim EE_Objekt As Object 'Objekt herstellen oDoc = ThisApplication.ActiveDocument 'Funktioniert nur, wenn Drawing und mindestens eine Ansicht vorhanden ist: If oDoc.DocumentType <> kDrawingDocumentObject Then Exit Sub If oDoc.ActiveSheet.DrawingViews.Count = 0 Then Exit Sub 'Ermittle die Hauptansicht und Hauptmaßstab EE_MainScale = oDoc.ActiveSheet.DrawingViews(1).Scale 'Ermittle weitere Ansichten J = 0 For I = 1 To oDoc.ActiveSheet.DrawingViews.Count 'Ermittle weitere Maßstäbe EE_TestScale = oDoc.ActiveSheet.DrawingViews(I).Scale 'Prüfe, ob gleich hauptmaßstab If EE_TestScale <> EE_MainScale Then 'Prüfe, ob schon als Nebenmaßstab vorhanden If J > 0 Then For K = 0 To J If EE_TestScale = EE_SiteScale(K) Then EE_TestScale = 0 Exit For End If Next K End If If EE_TestScale <> 0 Then 'Nimm in die Liste auf EE_SiteScale(J) = EE_TestScale J = J + 1 'Die liste ist begrenzt... If J = 11 Then Exit For End If End If Next I EE_Text = EE_FormatScale(EE_MainScale) If J > 0 Then EE_Text = EE_Text + " (" For I = 0 To J - 1 If (I > 0) And (I < 2) Then EE_Text = EE_Text + " " End If If (I > 1) Then EE_Text = EE_Text + ", " End If EE_Text = EE_Text + EE_FormatScale(EE_SiteScale(I)) Next I EE_Text = EE_Text + ")" End If 'Füge Zeichenfolge ein 'Maßstab vorhanden? EE_Da = False For Each EE_Prop In oDoc.PropertySets("{D5CDD505-2E9C-101B-9397-08002B2CF9AE}") 'Benutzerdefiniert If EE_Prop.Name = "Massstab" Then EE_Da = True Exit For End If Next If EE_Da Then oDoc.PropertySets("{D5CDD505-2E9C-101B-9397-08002B2CF9AE}").Item("Massstab").Value = EE_Text Else oDoc.PropertySets("{D5CDD505-2E9C-101B-9397-08002B2CF9AE}").Add EE_Text, "Massstab" End If End Sub Public Function GetFilename(ByVal Path As String) As String On Error Resume Next GetFilename = Mid(Path, Len(GetPath(Path)) + 1, Len(Path) - Len(GetPath(Path))) End Function Public Function GetPath(ByVal Pfad As String) As String On Error Resume Next Dim I As Integer Dim iPos As Integer iPos = InStrRev(Pfad, "\", , vbBinaryCompare) GetPath = Mid(Pfad, 1, iPos) End Function
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
Mike
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live." - John F. Woods
Message 3 of 10
i tried your code, but i didn´t work.
As attachment you find the list of errors.
I tried another way:
Sub Main()
InventorVb.RunMacro("Dokumentprojekt", "Modul1", "WieGezSpiegelbildlich")
InventorVb.RunMacro("Dokumentprojekt", "Modul1", "Massstab")
InventorVb.RunMacro("Dokumentprojekt", "Modul1", "WerkstoffZugewiesen")
End Sub
This worked for a while, but since today it sometimes doesn´t work and says something like
" There is no Module "Modul1" in the active VBA Projekt "Dokumentprojekt" "
Why is it that it works most of the time?
Message 4 of 10
saainsworth
I'm having the same difficulty.  It looks like the ilogic InventorVb.RunMacro cannot decide which document project to use if there is more than one document open.  It also matters which order the documents are opened.  I believe that the ilogic command is finding the first documentproject in the visual basic project tree and looking for the macro in there.  If it does not find it it throws an error.
I do not know the fix for this and I would appreciate insites anyone might have on how to fix this.
Message 5 of 10
saainsworth
I have found a work around.  Rename the DocumentProject in the vba editor to something unique to that template like "DocumentProjectXYZ".  Then if other files are open the ilogic command is not fooled by other DocumentProjects <<the default name in all inventor templates.  If more than one file that was created from that template is open it does not matter as the VBA code should be the same and it will find it and run it in either of the DocumentProjectXYZ's
Message 6 of 10
Owner2229
Hi, you forgot to attach the errors.
You don't have to call the modules by "RunMacro...", they've to be called as modules, you can try this instead:
Sub Main()
    Massstab()
End Sub
Mike
Message 7 of 10
@Owner2229
Sorry, this page doesn´t work as it is supposed to do with Firefox...
Now it should be in the attachment.
Also i tried your last recommendation, but since our main VBA Project is password protectet, and the one who hast the password will not come back before next week, i am not able to test it.
See the error in attachment.
edit:
@saainsworth
i changed the code to a unique name. We are going to test this a few days. Lets see if it is going to work.
Message 8 of 10
Owner2229
Here are the errors corected. Hightlighted so you can see them (on rows 13, 15, 19, 21 and 121). The row 52 didn't need to be there.
Option Explicit
Sub Main()
    Massstab()
End Sub
  If S >= 1 Then
      EE_FormatScale = Microsoft.VisualBasic.Strings.Format(S, "0") + ":1"
    Else
      EE_FormatScale = Microsoft.VisualBasic.Strings.Format(S, "0.0") + ":1"
    End If
  Else
      EE_FormatScale = "1:" + Microsoft.VisualBasic.Strings.Format(1 / S, "0")
    Else
      EE_FormatScale = "1:" + Microsoft.VisualBasic.Strings.Format(1 / S, "0.0")
    End If
  End If
End Function
End Sub
    Dim sName As String
    'Objekt herstellen
End Sub
Sub Massstab()
  'Objekt herstellen
  J = 0
      If J > 0 Then
        For K = 0 To J
            EE_TestScale = 0
            Exit For
          End If
        Next K
      End If
        J = J + 1
      End If
    End If
  Next I
  If J > 0 Then
    For I = 0 To J - 1
      End If
      If (I > 1) Then
      End If
    Next I
  End If
  'Maßstab vorhanden?
  EE_Da = False
      EE_Da = True
      Exit For
    End If
  Next
  If EE_Da Then
  Else
    oDoc.PropertySets("{D5CDD505-2E9C-101B-9397-08002B2CF9AE}").Add(EE_Text, "Massstab")
  End If
End Sub
End Function
    Dim I As Integer
    Dim iPos As Integer
End Function
Mike
Message 9 of 10
rossano_praderi
You can also use my opensource Addin which enable the vba autoruns functionalities (you doesn't need to change your macro).
Look at my signature.
Bregs
Rossano Praderi
If my post answers your question, please click the "Accept as Solution"
button. This helps everyone find answers more quickly!
Message 10 of 10
It seems that your code is working, there were no more errors.
So thanks for your help, and of course, thanks for every other suggestion.
