Macro - Count Extrude or Revolved features
isocam
isocam
Can anybody help?
I have a Inventor part (ipt) open.
I want to check if the part contains more than one "extrude" or "revolved" features.
Does anybody know how to do this with a Inventor macro?
All I need to do at present is to put the value in a message box
eg:
Number of extruded features = 4
Many thanks in advance!!!
Darren
Owner2229
Hi, something like this?
Dim oDoc As Document = ThisApplication.ActiveDocument
Dim oDef As ComponentDefinition = oDoc.Componentdefinition
Dim Revolve As Integer = 0
Dim Extrude As Integer = 0
Dim oFt As PartFeature
For Each oFT In oDef.Features
    If oFT.Type.ToString = "kRevolveFeatureObject" Then
        Revolve = Revolve + 1
    Else If oFT.Type.ToString = "kExtrudeFeatureObject" Then
        Extrude = Extrude + 1
Next
MsgBox("Revolve features: " & Revolve & vbLf & "Extrude features: " & Extrude)
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
Mike
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live." - John F. Woods
