Varying printed line weights in Inventor 2016
I want to make my lines print in varying weights, or even colors. How do I make hidden lines print thinner than the visible lines in Inventor 2016?
Hi!
You need to change the Layer thickness in the Style Lybrary.
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
