VB Get the angle in degree of the Y axis in my current view
11:15 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hey guys,
it's a bit complicated to explain WHY - but I need to get the angle of the Y axis in the current view. The picture helps to explain what I need.
I have put together a code to turn the screen around the axis that stands vertical on my screendisplay (not the UCS axis!).
If I would be able to measure how many degree the Y axis in my current view is off, let's say 5°, than I can rotate the view -5° back with my function below.
Do you have any idea how to measure the angle?
Public Sub RotateMe()
Call RotateAroundDisplayAxis("Z", -5)
End Sub
Public Sub RotateAroundDisplayAxis(ByVal axis As String, ByVal degree As Integer, Optional ByVal CW As Boolean = True)
' collected by PS 2020.10.05
' This example simply rotates the view around an axis of the actual view - not the UCS!
' turning around the axis vertical to the screen from: http://ww3.cad.de/foren/ubb/Forum258/HTML/000587.shtml
' turning around the vertical & horizontal axis of the screen from: https://forums.autodesk.com/t5/inventor-customization/camera-upvector/td-p/757637
Dim oView As View
Set oView = ThisApplication.ActiveView
Dim oCamera As camera
Set oCamera = oView.camera
Select Case axis
Case "Z"
Dim uVector As UnitVector
ox = oCamera.Eye.x - oCamera.Target.x
oy = oCamera.Eye.y - oCamera.Target.y
oz = oCamera.Eye.Z - oCamera.Target.Z
Set oNewUp = ThisApplication.TransientGeometry.CreateUnitVector(ox, oy, oz)
If CW Then 'rotate CW
oCamera.UpVector = oNewUp.CrossProduct(oCamera.UpVector)
Else 'rotate CCW
oCamera.UpVector = oCamera.UpVector.CrossProduct(oNewUp)
End If
Case "X", "Y"
Dim FPoint As Point2d 'rotation points
Dim TPoint As Point2d
Dim rVal As Double 'rotation values
Dim yVal As Double
Dim radV As Double
radV = Math.Atn(1) / 2.25 'PS: Math.Atn(1) = 45°
rVal = degree * -radV
Select Case axis
Case "X"
Set FPoint = ThisApplication.TransientGeometry.CreatePoint2d(0, 0)
Set TPoint = ThisApplication.TransientGeometry.CreatePoint2d(0, rVal)
Case "Y"
Set TPoint = ThisApplication.TransientGeometry.CreatePoint2d(rVal, 0)
End Select
Else 'rotate CCW
Select Case axis
Case "X"
Set FPoint = ThisApplication.TransientGeometry.CreatePoint2d(0, rVal)
Set TPoint = ThisApplication.TransientGeometry.CreatePoint2d(0, 0)
Case "Y"
Set FPoint = ThisApplication.TransientGeometry.CreatePoint2d(rVal, 0)
End Select
End If
oCamera.ComputeWithMouseInput FPoint, TPoint, 0, kRotateViewOperation
End Select
oCamera.Apply
oCamera.Fit
End Sub
