Adding WorkPlane By Using AddByTwoPlanes in Part Environment
KKizildemir
KKizildemir
Hi everyone,
I am trying to add a work plane by using 'AddByTwoPlanes' method in the part environment. Here is VBA code:
Sub CreateWP()
    Dim oPartDoc As PartDocument
    Set oPartDoc = ThisApplication.ActiveDocument
    Dim oPartCD As PartComponentDefinition
    Set oPartCD = oPartDoc.ComponentDefinition
    Dim WP1 As WorkPlane
    Set WP1 = oPartCD.WorkPlanes.Item(1)
    Dim WP2 As WorkPlane
    Set WP2 = oPartCD.WorkPlanes.Item(2)
    Dim oWPlane As WorkPlane
    Set oWPlane = oPartCD.WorkPlanes.AddByTwoPlanes(WP1, WP2)
End Sub
All the other work plane adding methods are working but unfortunately I am not able to use this method. When I run the code, oWPlane returns nothing after a run-time error.
Any comments on this?
Thanks!
Signature
website
emailskypelinkedinyoutubeemail
Michael.Navara
This is because work planes are perpendicular.  WorkPlanes(1) is YZ and WorkPlanes(2) is XZ. In this case the third argument QuadrantPoint is required.
See API documentation of this function for more information
clutsa
Can you give an example of creating a quadrantpoint? I don't see it in the object browser and the function help text simply calls it [QuadrantPoint] not "as" any other object type.
If I've helped you, please help me by supporting this idea.
Mass Override for Each Model State
Custom Glyph Icon for iMates
Michael.Navara
Here is the final code
Sub CreateWP()
    Dim oQuadrantPoint As Point
    'WorkPlane to quadrants 1-3
    'Set oQuadrantPoint = ThisApplication.TransientGeometry.CreatePoint(1, 1, 0)
    'WorkPlane to quadrants 2-4
    Set oQuadrantPoint = ThisApplication.TransientGeometry.CreatePoint(-1, 1, 0)
    Set oWPlane = oPartCD.WorkPlanes.AddByTwoPlanes(WP1, WP2, oQuadrantPoint)
End Sub
KKizildemir
Thanks @Michael.Navara , it works for me.
But I really don't understand what the quadrant point is. Can you please give more information about this?
Signature
website
Michael.Navara
Quadrant point specifies concrete result for given inputs when multiple solutions is possible.
KKizildemir
Great explanation, thank you. It's all clear now.
Kind regards!
Signature
website
