VB error messages
VB error messages
andrew_canfield
VB error messages
andrew_canfield
Hello
I've followed a post on AU to create an Inventor add in.
Used a downloaded 2018 pre-configured template (for visual studio) & saw this error:
then started again without the template - like the tutorial!
Tricky to know what to try next..
Regards
Andrew
andrew_canfield
i missed a word out. Doh
should be
Dim partDoc As Inventor.PartDocument = invApp.ActiveDocument
bradeneuropeArthur
Dim PartDoc as inventor.PartDocument= invApp.ActiveDocument
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
bradeneuropeArthur
@andrew_canfield
That was close.
Good to hear you solved it!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
