Vault Change Life cycle State In Inventor with Ilogic ?
gildas.lincot
gildas.lincot
I would like to know if it is possible to change the lifecycle in Vault directly from inventor with Ilogic?
I would like to be able to go directly from a state of "work in progress" to "validated".
I could use this command :
ThisApplication.CommandManager.ControlDefinitions.Item("VaultChangeStateTop").Execute
But it not realy what i want...
I have already created a rule from this post (Vault Lifecycle State of model through drawing - Autodesk Community - Inventor) to see the status, I would now like to modify it directly.
Is it possible ?
Is there someone that can help me ?
bradeneuropeArthur
You will need to use the Vault API for this.
This could be helpful for you.
Let me know if you need further support.
https://www.autodesk.com/autodesk-university/class/Breaking-into-the-Vault-iLogic-Edition-2023
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
