Function for creating linear dimension on work planes
mat_hijs
Message 1 of 1
mat_hijs
I've created a function to create a linear dimension on two workplanes. I made this so that it looks in the referenced document and then gets the occurrence with a specific name. This works fine when I have an assembly on the drawing and have the work planes in a component, but sometimes I have a part on the drawing. I'd like to be able to use the same function to dimension this part by leaving the argument for the occurrence name empty. Can anyone suggest how to do this without either writing two separate functions or writing one function with a lot of repeated code for the separate cases?
I have attached an example containing a rule that works for the assembly view, but at the moment not the part view.
Here is the same code as that rule:
Sub Main
' Set a reference to the Drawing Document
Dim oDrawDoc As DrawingDocument = ThisApplication.ActiveEditDocument
' Set a reference to the Sheets
Dim oSheets As Sheets = oDrawDoc.Sheets
' Set a reference to the Drawing Sheet
Dim oSheet As Sheet = oDrawDoc.ActiveSheet
' Set a reference to the Drawing Views
Dim oDrawingViews As DrawingViews = oSheet.DrawingViews
Dim sDrawingViewNameAsm As String = "ViewAssembly"
Dim sDrawingViewNamePart As String = "ViewPart"
Dim oDrawingViewAsm As DrawingView
Dim oDrawingViewPart As DrawingView
For i As Integer = 1 To oDrawingViews.Count
	If oDrawingViews.Item(i).Name = sDrawingViewNameAsm Then oDrawingViewAsm = oDrawingViews.Item(i)
	If oDrawingViews.Item(i).Name = sDrawingViewNamePart Then oDrawingViewPart = oDrawingViews.Item(i)
Next
' Create Dimensions
CreateLinearDimensionHorizontal(oSheet, oDrawingViewAsm, "Bottom", 1, "WPL_0_Breedte", "WPL_100_Breedte", "Test")
CreateLinearDimensionHorizontal(oSheet, oDrawingViewAsm, "Bottom", 2, "WPL_0_Breedte", "WPL_200_Breedte", "Test")
End Sub
Public Function CreateLinearDimensionHorizontal(ByVal oSheet As Sheet, ByVal oDrawingView As DrawingView, ByVal sDimensionSide As String, ByVal dDimensionLevel As Double, ByVal sWorkPlaneName1 As String, ByVal sWorkPlaneName2 As String, ByVal sOccName As String) As LinearGeneralDimension
	' Set references to documents, and component definitions
	Dim oModelAsm As AssemblyDocument = oDrawingView.ReferencedDocumentDescriptor.ReferencedDocument
	Dim oModelAsmCompDef As AssemblyComponentDefinition = oModelAsm.ComponentDefinition
	Dim oModelPart As ComponentOccurrence = oModelAsmCompDef.Occurrences.ItemByName(sOccName)
	Dim oModelPartDoc As PartDocument = oModelPart.Definition.Document
	Dim oModelPartCompDef As PartComponentDefinition = oModelPartDoc.ComponentDefinition
	' Set references to workplanes
	Dim oWPlane1 As WorkPlane = oModelPartCompDef.WorkPlanes.Item(sWorkPlaneName1)
	Dim oWPlane2 As WorkPlane = oModelPartCompDef.WorkPlanes.Item(sWorkPlaneName2)
	' Create proxies for workplanes
	Dim oWPlane1Proxy As WorkPlaneProxy
	 oModelPart.CreateGeometryProxy(oWPlane1, oWPlane1Proxy)
	Dim oWPlane2Proxy As WorkPlaneProxy
	 oModelPart.CreateGeometryProxy(oWPlane2, oWPlane2Proxy)
	' Include workplanes and turn visibility off
	oDrawingView.SetIncludeStatus(oWPlane1Proxy, True)
	oDrawingView.SetVisibility(oWPlane1Proxy, False)
	oDrawingView.SetIncludeStatus(oWPlane2Proxy, True)
	oDrawingView.SetVisibility(oWPlane2Proxy, False)
	' Create geometry intents for workplanes
	Dim oWPlane1Intent As GeometryIntent
	Dim oWPlane2Intent As GeometryIntent
	Dim oCenterline As Centerline
	For Each oCenterline In oSheet.Centerlines
	    If oCenterline.ModelWorkFeature Is oWPlane1Proxy Then
	        oWPlane1Intent = oSheet.CreateGeometryIntent(oCenterline)
	    ElseIf oCenterline.ModelWorkFeature Is oWPlane2Proxy Then
	        oWPlane2Intent = oSheet.CreateGeometryIntent(oCenterline)
	Next
	' Set spacing between dimensions
	Dim oDimSpacing As Double = 1
	' Get positions of view extents
	Dim oDrawingViewBottom As Double = oDrawingView.Top - oDrawingView.Height
	Dim oDrawingViewTop As Double = oDrawingView.Top
	' Set level of dimension
	Dim oDimensionLevel As Double = dDimensionLevel
	' Set dimension position
	Dim oDrawingViewDimPosition As Double
	If sDimensionSide = "Bottom" Then
		oDrawingViewDimPosition = oDrawingViewBottom
	ElseIf sDimensionSide = "Top" Then
		oDrawingViewDimPosition = oDrawingViewTop
	' Create transient point
	Dim oPointY As Double
		oPointY = oDrawingViewDimPosition - oDimensionLevel * oDimSpacing
		oPointY = oDrawingViewDimPosition + oDimensionLevel * oDimSpacing
	Dim oPointX As Double = 0
	Dim oPoint As Point2d = ThisApplication.TransientGeometry.CreatePoint2d(oPointX, oPointY)
	' Create linear dimension
	Dim oGeneralDims = oSheet.DrawingDimensions.GeneralDimensions
	Dim oLinearDim = oGeneralDims.AddLinear(oPoint, oWPlane1Intent, oWPlane2Intent)
	oLinearDim.CenterText
	' Return the result
	Return oLinearDim
End Function
Replies (0)
