Using iLogic to look for missing balloons
Message 1 of 12
I found this code by "inventor guru" which works perfect to list all missing ballons. But it doesn't work for iParts, as it lists ALL the missing balloons, not checking against active BOM (also shows the hidden members)
I would think its possible to modify it to check if QTY is more than 0, then list the items.
Anyone know how to achieve this?
Dim oDrawDoc As DrawingDocument = ThisDoc.Document
 Dim oSheet As Sheet = oDrawDoc.ActiveSheet
 Dim oPartsList As PartsList = oSheet.PartsLists.Item(1)
 Dim s As String
 Dim msg as String = ""
For Each oRow As PartsListRow In oPartsList.PartsListRows
 If Not oRow.Ballooned Then
 s = ""
For Each oCell As PartsListCell In oRow
 s = s & oCell.Value & " "
Next
 msg = msg & s & vbNewLine
 Next
'show results
 MsgBox(msg)
Replies (11)
Message 2 of 12
waynehelley
Try using this...
If Not oRow.Ballooned And oRow.Item(2).Value > 0 Then
You will just need to tweak it so that the numeric value within the brackets, matches the column number of the Qty column.
Wayne Helley
Inventor 2013 Certified Professional
Autodesk Inventor Professional 2023
Visual Studio 2022
Windows 10 Pro, 64-bit
Message 3 of 12
Oh, perfect. Thanks!
I have a lot of piping in my assembly, which reports qty as e.g. "100.00 mm". So I get an error saying "Conversion from string "100.000 mm" to type 'Double' is not valid."
Do you know a way to avoid this?
Message 4 of 12
bradeneuropeArthur
I don't get any error message!
The values are represented in the message!
if your code is different then use:
.Tostring to represent the value.
or
.Cstr to represent the value.
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 5 of 12
This is because I have piping in the assembly. Instead of reporting QTY as 1 or 2, it reports the pipe length (in my example, 100mm) On "regular" assemblies I see that it works fine.
Message 6 of 12
bradeneuropeArthur
I don't get a error for these components with ie 100mm Qty.
please post  a screen shot
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 7 of 12
Oh, that was strange. It works if I manually remove "mm", but as long as I have text, if wont check if the value is large than 0...
Message 8 of 12
bradeneuropeArthur
I see the error too.
Do this to solve it:
If Not oRow.Ballooned And oRow.Item(2).Value > "0" Then
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 9 of 12
Perfect, thanks a lot!
Message 10 of 12
freesbee
...my task is similar but a little bit different, and currently I am in trouble in enumerating balloons attached to other balloons.
For example in the situation under here 407 and 408 are definitely referring to the correct PartlistROW, but they are ignored by the ActiveSheet.Balloons collection, and I am not able to identify the right way to catch them.
Any idea?
Massimo Frison
CAD R&D // PDM Admin · Hekuma GmbH
Message 11 of 12
dg8MW9N
@freesbee
You may be able to apply the last iLogic code in the following post to help:
Solved: Inventor 2022 Parts List Balloon Indicating Icons - Autodesk Community - Inventor
Thanks to @Curtis_Waguespack
Message 12 of 12
pl.sivakumar
Thanks for your code of Missing balloon,
I  made a small correction on that, If not found ( No missing balloon)Message box will not sow,
If msg = ""
Else
 MsgBox(msg)
 Dim s As String
 Dim msg As String = ""
 s = ""
Next
 Next
If msg = ""
	Else
'show results
 MsgBox(msg)
