Excel find Column
Excel find Column
mk92
Excel find Column
mk92
i try to find a column with iLogic. I got two Headlines in the first row of my Excel. "Type 1" and "Type 2". Also a Parameter in Inventor "Type" which has the Inputs "Type 1" and "Type 2"
The Headlines are in Column A and B. It the Parameter in Inventor is "Type 2" so my result should be coulum "B".
Is there a way to do that?
Kind regards
bradeneuropeArthur
No I logic is needed.
Embed the excel list or link it to the inventor part or assembly.
The parameters in excel are now visible inventor
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
mk92
Thanks for your answer. Unfortunately i need to do it with iLogic because i cant embed the Excel Sheet in my case.
