Using iLogic to create DXF files of multiple sheet metal flat patterns.
Thomas_Savage
Advisor Advisor
Thomas_Savage
Hello. I am trying to get iLogic to export multiple individual DXF files to AutoCAD, from an Assembly containing multiple sheet metal parts. So each file in AutoCAD is an individual sheet metal flat pattern part from my assembly.
I have been searching for a code but haven't found one that works. Is it even possible to do this? I am quite new to iLogic, So need some advice. I have been using the snippet: Export DXF from IDW. But doesn't work.
Any help will be much appreciated
Thomas.
Thomas Savage
Design Engineer
tolgay.hickiran
Hey Thomas,
There are a lot of different threads about this one of which is : http://forums.autodesk.com/t5/inventor-customization/consolidate-flat-pattern-of-multiple-parts-from...
You can find your needed code in this thread.
Some worthwhile ideas
Copy Design should rename ilogic Rules too!
Why Nastran In-CAD doesn't have an SDK?IMPLEMENTED!
Tolgay Hickiran
Founding Partner
SignatureSignature
website
emailskypelinkedinyoutubeemail
