Upload/CheckIn Files into Vault using inventor API
nishantkumat5921
nishantkumat5921
Hi all,
I am trying to Upload/Check-In IPT/IAM into Autodesk vault using Inventor API.
I have tried below line of code but that again brings a popup for selection of relationship is there any other way to upload files from inventor directly and not use the Vault server?
Dim oControlDef As Inventor.ControlDefinition oControlDef = ThisApplication.CommandManager.ControlDefinitions.Item("VaultCheckinTop") oControlDef.Execute2(True)
Thanks in advance
bradeneuropeArthur
You better can use the Vault API here.
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
nishantkumat5921
@bradeneuropeArthur thanks for the quick reply. I have tried using vault API and when uploading IAM files what happens is only the Parent file is Checked-In, the associated child files and dependents also needs to be Checked-In. So if you could share some thoughts on API for that it would be helpful.
This issue of dependency will not be there when Checking-In using inventor as inventor will take care of Uploading the dependencies.
