Exporting a dimension list to an excel sheet
Thomas_DIETSCHYFXTLC
I have a problem with the rule I wrote, it exports all the dimensions and tolerance and position to an Excel sheet.
The problem is that for the radius dimensions the rule does not export and moreover I have an error and I can't find out where the problem comes from. Can anyone help me?
AddReference "Microsoft.Office.Interop.Excel.dll"
Imports exe = Microsoft.Office.Interop.Excel
Dim oXLFile As String = "C:\TravailVault\revuplan.xlsx"
Dim oSheet As String = "Feuil1"
Dim oExcel As New Microsoft.Office.Interop.Excel.ApplicationClass
Dim oWB As Microsoft.Office.Interop.Excel.Workbook = oExcel.Workbooks.Add'.Open(oXLFile)
Dim oWS As Microsoft.Office.Interop.Excel.Worksheet = oWB.Worksheets.Item(oSheet)
Dim oCells As Microsoft.Office.Interop.Excel.Range = oWS.Cells
'oCells.item(2,1).value= b.Text.Text.ToString
Dim a As Inventor.DrawingDocument = ThisDrawing.Document
Dim s As Inventor.Sheet = a.ActiveSheet
Dim i As Integer = 1
'Dim E As Integer = Nombre_de_vue
Dim ord
Dim abss
Dim Tol_ang = iProperties.Value("Custom", "Tol_ang")
Dim Tol_line = iProperties.Value("Custom", "Tol_line")
Dim Tol_cham = iProperties.Value("Custom", "Tol_cham")
Dim Tol_cong = iProperties.Value("Custom", "Tol_cong")
oCells.Item(1, 2).value = "Cote"
oCells.Item(1, 3).value = "Tolerance Superieur"
oCells.Item(1, 4).value = "Tolerance inferieur"
oCells.Item(1, 1).value = "Position cote"
For Each b As Inventor.DrawingDimension In s.DrawingDimensions
	Dim v As Integer = b.Text.Origin.X
	Dim y As Integer = b.Text.Origin.Y
	If s.Size = 9997 Then 'format de feuille
		If s.Orientation = 10243 Then 'Portrait
			If v<5.75 Then
				ord = "D"
			If v >5.75 Then
				If x<10.5 Then
					ord = "C"
			If v >10.5 Then
				If x<15.25 Then
					ord = "B"
			If v >15.25 Then
				ord = "A"
			If y < 7.925 Then
				abss = "1"
			If y >7.925 Then
				If x<14.85 Then
					abss = "2"
			If y >14.85 Then
				If x<21.775 Then
					abss = "3"
			If y >21.775 Then
				abss = "4"
		If s.Orientation = 10242 Then 'Paysage
			If v<7.925 Then
				ord = "D"
			If v >7.925 Then
				If x<14.85 Then
					ord = "C"
			If v >14.85 Then
				If x<21.775 Then
					ord = "B"
			If v >21.775 Then
				ord = "A"
			If y < 5.75 Then
				abss = "1"
			If y >5.75 Then
				If x<10.5 Then
					abss = "2"
			If y >10.5 Then
				If x<15.25 Then
					abss = "3"
			If y >15.25 Then
				abss = "4"
If b.DimensionType = DimensionTypeEnum.kArcLengthForeshortenedDimensionType Then
		If b.Tolerance.ToleranceType = 31236 Then
			oCells.Item(i, 2).value = b.Text.Text
			oCells.Item(i, 3).value = b.Tolerance.Upper * 10
			oCells.Item(i, 4).value = b.Tolerance.Lower * 10
			oCells.Item(i, 1).value = ord & "-" & abss
		If b.Tolerance.ToleranceType = 31244 Then
		If b.Tolerance.ToleranceType = 31233 Then
		If b.Tolerance.ToleranceType = 31235 Then
			Dim du As Double = "+" & (b.Tolerance.Upper * 10)
			Dim dl As Double = "-" & (b.Tolerance.Upper * 10)
			'MsgBox("+"&(b.Tolerance.Upper*10).ToString)
			oCells.Item(i, 3).value = b.Tolerance.Upper * 10'du '"="+"" &(b.Tolerance.Upper*10)'"p"'"+" & b.Tolerance.Upper*10
			oCells.Item(i, 4).value = dl'"-" &(b.Tolerance.Lower*10)'"q"'"-" &b.Tolerance.Lower*10
		If b.Tolerance.ToleranceType = 31246 Then
			oCells.Item(i, 2).value = (Replace((Replace(b.Text.Text.ToString, "(", "")), ")", ""))'Replace(b.Text.Text.ToString,"-","")
			oCells.Item(i, 3).value = Tol_line
			oCells.Item(i, 4).value = "-" & Tol_line
If b.DimensionType = DimensionTypeEnum.kAngularDimensionType Then  'Partie cote angulaire
			oCells.Item(i, 3).value = ((b.Tolerance.Upper * 180) / PI) & "°"
			oCells.Item(i, 4).value = ((b.Tolerance.Lower * 180) / PI) & "°"
			oCells.Item(i, 3).value = Tol_ang '((b.Tolerance.Upper * 180) / PI) & "°"
			oCells.Item(i, 4).value = Tol_ang'((b.Tolerance.Lower * 180) / PI) & "°"
			Dim du As Double = "+" & ((b.Tolerance.Upper * 180) / PI)
			Dim dl As Double = "-" & ((b.Tolerance.Upper * 180) / PI)
			oCells.Item(i, 3).value = Tol_ang & "°"'du '"="+"" &(b.Tolerance.Upper*10)'"p"'"+" & b.Tolerance.Upper*10
			oCells.Item(i, 4).value = Tol_ang & "°"'"-" &(b.Tolerance.Lower*10)'"q"'"-" &b.Tolerance.Lower*10
	'If b.DimensionType = DimensionTypeEnum.
	'End If
	If b.DimensionType = DimensionTypeEnum.kAngularForeshortenedDimensionType Then  'Partie cote angulaire
			Dim du As Double = "+" & ((b.Tolerance.Upper * 180) / PI) '& "°"
			Dim dl As Double = "-" & ((b.Tolerance.Upper * 180) / PI) '& "°"
If b.DimensionType = DimensionTypeEnum.kDiametricDimensionType Then
			oCells.Item(i, 4).value = Tol_line
	If b.DimensionType = DimensionTypeEnum.kAlignedDimensionType Then
	If b.DimensionType = DimensionTypeEnum.kAlignedToCurveDimensionType Then
			oCells.Item(i, 4).value = d1'"-" &(b.Tolerance.Lower*10)'"q"'"-" &b.Tolerance.Lower*10
	If b.DimensionType = DimensionTypeEnum.kArcLengthDimensionType Then
	If b.DimensionType = DimensionTypeEnum.kHorizontalDimensionType Then
	If b.DimensionType = DimensionTypeEnum.kLinearForeshortenedDimensionType Then
	If b.DimensionType = DimensionTypeEnum.kNormalToCurveDimensionType Then
	If b.DimensionType = DimensionTypeEnum.kParallelDiametricDimensionType Then
	If b.DimensionType = DimensionTypeEnum.kSymmetricDimensionType Then
	If b.DimensionType = DimensionTypeEnum.kVerticalDimensionType Then
Next
For Each d As Inventor.DrawingNote In s.DrawingNotes
	i = i + 1
	Dim O As Integer = d.Position.X
	Dim P As Integer = d.Position.Y
			If O<5.75 Then
				ord = "D"
			If O >5.75 Then
				If O<10.5 Then
					ord = "C"
			If O >10.5 Then
				If O<15.25 Then
					ord = "B"
			If O >15.25 Then
				ord = "A"
			If P < 7.925 Then
				abss = "1"
			If P >7.925 Then
				If x<14.85 Then
					abss = "2"
			If P >14.85 Then
				If x<21.775 Then
					abss = "3"
			If P >21.775 Then
				abss = "4"
			If O<7.925 Then
				ord = "D"
			If O >7.925 Then
				If x<14.85 Then
					ord = "C"
			If O >14.85 Then
				If x<21.775 Then
					ord = "B"
			If O >21.775 Then
				ord = "A"
			If P < 5.75 Then
				abss = "1"
			If P >5.75 Then
				If x<10.5 Then
					abss = "2"
			If P >10.5 Then
				If x<15.25 Then
					abss = "3"
			If P >15.25 Then
				abss = "4"
	If d.Type = 117488384 Then
		oCells.Item(i, 2).value = d.Text
	Next
oWB.SaveAs("C:\TravailVault\" & a.DisplayName & ".xlsx")
oWB.Close
WCrihfield
Hi @Thomas_DIETSCHYFXTLC.  Wow. 😲 That is a really long rule.  In the future, when you want to share a really long code, you can simply attach it to your forum post as a text file, instead of copying and pasting it into a code block within the forum post.  It's easier on the eyes that way.
Anyways, one thing I saw in a few different places throughout your code was where you were storing the value of something like a DrawingDimension.Text.Origin.X value or Position.X value to an Integer type variable.  Those Point2D.X properties return a Double type value, not an Integer, so you should change the Type of those variables to Double, instead of Integer.  I see in some places where you are even checking the returned value against a value with decimal places in it.  Integer's are whole numbers, and do not include a decimal place or any data to the right of where the decimal would be, so when you store Double type data to an Integer type variable, the value may be getting rounded off to a whole number.
Wesley Crihfield
(Not an Autodesk Employee)
Ok but I have this error:
System.MissingMemberException: Le membre public 'DimensionType' du type 'RadiusGeneralDimension' est introuvable.
à Microsoft.VisualBasic.CompilerServices.LateBinding.LateGet(Object o, Type objType, String name, Object[] args, String[] paramnames, Boolean[] CopyBack)
à Microsoft.VisualBasic.CompilerServices.NewLateBinding.LateGet(Object Instance, Type Type, String MemberName, Object[] Arguments, String[] ArgumentNames, Type[] TypeArguments, Boolean[] CopyBack)
à ThisRule.Main()
à Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
à iLogic.RuleEvalContainer.ExecRuleEval(String execRule)
And I can't figure out where it comes from.
Michael.Navara
Exception in your code was thrown because property "DimensionType" is not implemented by all dimension types.
Try to change your code to check type directly using TryCast . This approach makes your code more readable and you can work with strongly-typed variable inside the methods (intellisense works much better)
Sub Main()
    Dim sheet As Sheet = ThisDrawing.ActiveSheet.Sheet
    For Each drawingDimension As DrawingDimension In sheet.DrawingDimensions
        TryProcessAngularGeneralDimension(TryCast(drawingDimension, AngularGeneralDimension))
        TryProcessDiameterGeneralDimension(TryCast(drawingDimension, DiameterGeneralDimension))
        TryProcessLinearGeneralDimension(TryCast(drawingDimension, LinearGeneralDimension))
        TryProcessRadiusGeneralDimension(TryCast(drawingDimension, RadiusGeneralDimension))
    Next
End Sub
Private Sub TryProcessAngularGeneralDimension(dimension As AngularGeneralDimension)
    If dimension Is Nothing Then Return
    'TODO: Do something useful with AngularGeneralDimension
End Sub
Private Sub TryProcessDiameterGeneralDimension(dimension As DiameterGeneralDimension)
    'TODO: Do something useful with DiameterGeneralDimension
End Sub
Private Sub TryProcessLinearGeneralDimension(dimension As LinearGeneralDimension)
    'TODO: Do something useful with LinearGeneralDimension
End Sub
Private Sub TryProcessRadiusGeneralDimension(dimension As RadiusGeneralDimension)
    'TODO: Do something useful with RadiusGeneralDimension
End Sub
