Update snapshot in presentation (VBA)?
anyone knews, how to access the options for snapshots in presentationdocuments?
In example I want to update the snapshot with VBA or if I want to add the name of the snapshot into properties.
chandra.shekar.g
Autodesk Support
Autodesk Support
Hi @Anonymous,
SnapShotView object can be obtained from presentation document using following VBA code. Unfortunately, "Update" method for PresentationSnapshotView is exposed in Inventor 2018.
Sub Main() Dim oDoc As PresentationDocument Set oDoc = ThisApplication.ActiveDocument Dim oScene As PresentationScene Set oScene = oDoc.Scenes.Item(1) Dim oView As PresentationSnapshotView Set oView = oScene.SnapshotViews.Item(1) End Sub
You can log this wish list at idea station using following link.
https://forums.autodesk.com/t5/inventor-ideas/idb-p/v1232/tab/most-recent
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
Okay. Thx. Thats okay. We will upgrade to IV2018 in summer.
