inventor ilogic to get and post data from an excel
hi all,
I am getting stuck when putting this together
my goal is to a build a rule/ button for my existing form:
1,that looks in a excel file on my "c:\" called "data.xls"
2, for it to look from the bottom up ( in column "C")  to the next cell with data in it and then move 1 down (to next empty line)
3, I then want it to take the valve from column "A" ( in that row) and input that as the part number
4, I then want to take the description from the model and input this into column "D" of the same row
5, save the document
if anyone can help thank you in advance
bradeneuropeArthur
Can you upload the data file as Xls or as Txt
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
please see attached upload this is the kind of thing I want to build.
