- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I made a Rule which makes a new sheet, adds Titleblock and Border. I'm using the AddDefaultBorder to place my border and then I give some values for customising its appearance (e.g. Zone Count).
However, I'm unable to remove the Center Marks which are part of the default border. Here is the main portion of the code (The bold parts are the code that doesn't seem to work):
Dim oSheetSize As DrawingSheetSizeEnum oSheetSize = oActiveSheet.Size Dim oOrientation As PageOrientationTypeEnum oOrientation = oActiveSheet.Orientation Dim sSheetName As String sSheetName = "Profile Sheet" Dim oProfileTitleBlockDef As TitleBlockDefinition oProfileTitleblockDef = oDrawDoc.TitleBlockDefinitions.Item("TitleBlock") Dim oNewSheet As Sheet oNewSheet = oDrawDoc.Sheets.Add(oSheetSize, oOrientation, sSheetName) 'Add Titleblock and Border oNewSheet.AddTitleBlock(oProfileTitleBlockDef) Dim HorizontalZoneCount As Long HorizontalZoneCount = 6 Dim HorizontalZoneLabelMode As BorderLabelModeEnum HorizontalZoneLabelMode = kBorderLabelModeNone Dim VerticalZoneCount As Long VerticalZoneCount = 4 Dim VerticalZoneLabelMode As BorderLabelModeEnum VerticalZoneLabelMode = kBorderLabelModeNone Dim Centermarks As Boolean Centermarks = False oNewSheet.AddDefaultBorder(HorizontalZoneCount, HorizontalZoneLabelMode, _
VerticalZoneCount, VerticalZoneLabelMode, Centermarks) 'oNewSheet.AddDefaultBorder(HorizontalZoneCount, HorizontalZoneLabelMode, _ ' VerticalZoneCount, VerticalZoneLabelMode, _ ' LabelFromBottomRight, DelimitByLines, _ ' Centermarks, TopMargin, BottomMargin, _ ' LeftMargin, RightMargin, TextStyle, _ ' TextLayer, LineLayer)
Thanks in Advance!
