Custom note based on formula
abhay.gilka
abhay.gilka
Hi ,
I am looking add to custom note which should prompt for an entry (numerical value) so that it generates a conversion value as general note using a simple multiplication or division formula.
For example, Prompted entry should be enter value in Newtons  and output in lbs
Prompted entry should be enter value in deg C  and output in DEG F
and so on.
Appreciate any help.Thanks!
A.Acheson
Here a few links that might get you started, api sample for adding general note
and function for unit conversion.
This sample contains prompted text
and how to add it to a text box.
All the samples are vba. To convert to ilogic/vb.net environment by using find replace to remove set and you can also remove sub and end sub lines.
You will likely need to run the rule manually to get a conversion to happen as there is limited event triggers.
Regards
Alan
