Replace a portion of the filename using iLogic
Jason_Aloot
Jason_Aloot
Good day.
I want to achieve on how to replace a portion of a part filename.
Example:
Before:
12345_PART1.ipt
After:
67890_PART1.ipt
Jason_Aloot
To make it clear.. I want to replace the filename in the iProperties.
A.Acheson
Are you replacing the file or just modifying the description /part number? Either way you can use string functions to isolate the section of the string that will change. Split could work here targeting the underscore. Microsoft examples are here and ilogic example here.
Post up an attempt and forum members can help out if you get stuck.
Regards
Alan
Jason_Aloot
Thanks for your quick reply. I am modifying the description on the iProperties.
I will look at the example links you provided. thanks again.
william
here's one example from a rule I use regularly to modify solid body names. I tweaked it slightly for your use with iProperties.
strDescription_Original = iProperties.Value("Project", "Description")
strFindText = InputBox("Enter the text to be replaced" & vbNewLine & "Description: " & strDescription_Original, "iLogic Find-Replace", FindText)
strReplaceText = InputBox("Replace With", "iLogic Find-Replace", ReplaceText)
strDescription_New = Replace(strDescription_Original, strFindText, strReplaceText)
iProperties.Value("Project", "Description") = strDescription_New
Another one could be
strDescription_Array = strDescription_Original.Split("_")
'strDescription_ArrayCount = UBound(strDescription_Array)
strVariable1 = strDescription_Array(0)
strReplaceText = InputBox("Enter Description Field 1", "iLogic Find-Replace", "####")
strDescription_New = Replace(strDescription_Original, strVariable1, strReplaceText)
MessageBox.Show("Description: " & iProperties.Value("Project", "Description"), "Title")
Jason_Aloot
thanks. This helps indeed!
I modified the part number instead of the description.
Jason_Aloot
This helps mo too to modify the code. cheers!
