Unable to get the Open property of the Workbooks class
JoãoASilva
JoãoASilva
Hello!
After solving my last issue in this post, I now get an error on one the computers here at work.
System.IO.File.Copy("Z:\Temp.Folders\JoaoASilva\Template.xlsm", oDestination,True) 'Create template copy
xlWorkbookTemp = xlApp.Workbooks.Open(oDestinationTemp) 'Open excel created by Inventor
xlWorkbook = xlApp.Workbooks.Open(oDestination) 'Open template copy
From the 3 machines I tested on, one of them gets this error:
The odd thing is that it opens the excel created by Inventor, but not the template copy.
They are both .xlsm files, and all the machines have the same version of Inventor, Excel and also the Trust Center definitions within Excel.
I also performed a Repair and Reset of office365 (like this post suggests) on the machine and the problem still occurs.
@johnsonshiue
Allow me to tag you, has this seems like such a specific error.
Thanks in advance,
JoãoASilva
João Silva
Mechanical Engineer
bradeneuropeArthur
Is the z drive a network drive. Use in that case servename not drive name!
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
JoãoASilva
Thanks for the suggestion.
Although it didn't solve the issue, it does seem like a good practice.
Both excel files are on a network drive, and Inventor manages to open one and not the other.
Every terminal is configured in the same way (Network drives, Inventor and excel configs and versions).
And everything is up to date (Inventor 2023.3 Build 359).
João Silva
Mechanical Engineer
