Getoject("inventor.application") creates a new inventor session
bradeneuropeArthur
Mentor Mentor
bradeneuropeArthur
  • Why is it the case that in ilogic Getoject("inventor.application") creates a new inventor session?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
WCrihfield
Hi @bradeneuropeArthur.  I am not sure why that might be happening.  When using GetObject method, did you provide an empty String as the first input, then "Inventor.Application" as the second input?  If not, that may be why it is doing that.  I just tested the following code in an iLogic rule, and it worked just fine for me using Inventor Pro 2024.0.1 version.
Dim InvApp As Inventor.Application = Nothing
Try
	InvApp = GetObject("", "Inventor.Application")
	Logger.Info("Running Instance Of Inventor Application Found")
Catch
	InvApp = CreateObject("Inventor.Application")
	Logger.Info("Created Instance Of Inventor Application")
End Try
If InvApp Is Nothing Then
	Logger.Debug("Inventor Application Not Found")
Else
	Logger.Debug("Inventor Application Found")
INFO| 2: >>---------------------------
INFO|Running Instance Of Inventor Application Found
DEBUG|Inventor Application Found
Wesley Crihfield
(Not an Autodesk Employee)
bradeneuropeArthur
Than this is a bug.
Please @johnsonshiue could you and your team take a look at this.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
rossano_praderi
The code sample posted by @WCrihfield as to work because is the right implementation, but you didn't post your code.
Maybe your code is buggy, would you like to show your code to us?
If my post answers your question, please click the "Accept as Solution"
button. This helps everyone find answers more quickly!
