Trying to round up parameters with the unit type mm in factory layouts
reggie.mostert
reggie.mostert
I'm trying to figure out how to round up parameters which are in mm. I have the following code which works in my multibody part/asset builder. But when i publis it and put in the factory enviroment i have pin point it doesn't go through the loop i made.
Dim UserParams As UserParameters
UserParams = ThisApplication.ActiveDocument.ComponentDefinition.Parameters.UserParameters
For Each Item In UserParams
 	If Item.Units = "mm" Then
		Dim Converter As Integer = Item.value * 10
	    Parameter(Item.name) = Ceil(Converter)
	End If
Next
RuleParametersOutput
InventorVb.DocumentUpdate()
 Combined with that finding and the fact that i don't see "mm" behind the numbers in the factory properties, makes me think the parameters are unitless there or something, which makes this code useless. Does anyone knows a way to make this work?
bradeneuropeArthur
What do you mean with publish?
What do you mean with factory environment?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
reggie.mostert
I mean publishing the asset and using it in the factory utilities addon
bradeneuropeArthur
Factory Design Suite!?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
reggie.mostert
Yes, that is correct
bradeneuropeArthur
I don't have that installed so I cannot help you further!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
reggie.mostert
Can anyone help me?
